Huawei Mate 20
1982-1994
Anyone knows how to turn off this Huawei home? I tried to find the app but couldn't find.
Are you using gesture? If not, you can just install launchers.
In fact, Huawei launcher is the most stable. So once you adb shell remove Huawei home, you can never use gesture till you reset the phone. I have no idea how to reinstall back through adb.
chenaz
Audiology93
How bout specs wise? Would it justify an approx $250 price difference?
Deciding between the 2 for recontracting...
If you don't mind better camera at the expense of a headphone jack, go for Mate 20 Pro. You'll also get a better display but have to spend a bit more on tempered glass.
Sent from HUAWEI Mate 20 using GAGT
1982-1994
It is draining my battery quite significantly
But I don't think Huawei launcher drains the battery. The culprit should be the Google map which is running in the background. How about you force stop it and see how is it?
chenaz
Not Google map. because the launcher itself drain 4% within 4 hours .
Google map drains because I am using it before that.
Since Huawei home is launcher then 4% maybe acceptable for 4 hour with 4% drain?
1982-1994
Not acceptable for me. Try using 3rd party launcher like nova. You can adb shell remove Huawei home as long as you don't need the gesture.
osh6
I am also on Starhub, not yet for this update.
My M1 line also not yet get this latest firmware, but my other 2 family member using the same phone on M1 line too, already gotten their update this afternoon.
