Huawei Mate 20
Blueberrytea
No uv glue which is what i like. It fits liquid crystal which is well known to lift up tempered glass compared to rugged armor. So it will fit rugged armor
Full adhesive type is supposedly better den UV/loca type unless it's Whitestone...cos those china type uv damn hard to remove over time
Audiology93
Just a short write up on the Mate 20 non pro version for the benefit of those who have not gotten one and planning of getting one.
My brother and I have both colours for me being the Black one and my brother having the blue one.
Initially I was really jealous of how cool the textured back looks on the blue and it certainly looks safer from scratches.
But after a month plus of usage and here's what I found out.
My brother's blue set is starting to get a few tiny Nick's around the bezel probably caused by taking it out of the case to clean.
There these tiny silver spots around th noe bezel near the headphone jack and charging port. Basically areas exposed and not covered by the case. I am guessing that such damages are more prominent maybe cause the blue colour is coated onto it. Therefore it's easier to get such damages.
My black on the other hand, I did not find any of such damages probably b cause the colour is a close to the original colour of the bezel. So did not show much wear. In fact still look as good as new.
On the downside. The black is a fingerprint magnet and its a worrying factor that it will scratch easily like chrome.
Other than all these, both looks gorgeous in their own way.
Its up to you if you are more comfortable dealing with fingerprint or scratches.
I probably will stick with the black for the durability to wear and tear.
Sent from HUAWEI HMA-L29 using GAGT
Speaking of nicks, I spotted 1 super tiny scratch on the top left corner when I took the phone out to clean :(. Mine also blue colour.
Sent from HUAWEI Mate 20 using GAGT
mrspid3r
How about the fingerprint scanner? Will it work for the mocoli tempered glass?
Chevalier
You guys on gigabit wifi and gigabit Internet, If you do a speedtest next to your router are you able to to hit abt 400-500mbps?
twinklingstars
Hi guys, I just gotten my mate 20 pro from the IT show over the last weekend. Any recommendations for the temepered glass or any other type of screen protector, went to red white mobile the other day and was told that the screen protector for mate 20 pro will only be restocked later this week. I'm looking at something that can cover the curved surface, no fingerprint recognition issues and if possible, provide some form of privacy shield.
also, any recommendations on casing? I have shortlisted Spigen Case Liquid Crystal as well as Otterbox Symmetry Series Clear Case. My concern for the Otterbox is, whether the casing turns yellow over time?
thank you!
molecule
Yeah, dirt and fine grain sand or stuff gets into the casing and the friction between the case daily causes these small nicks and scratches, not just limited to Huawei phones but all phones unless cleaned out frequently. Often accumulates at the corners of casing.
feryox
thank you!
Make sure the sp u using will not be pushed out by the case u using.
My col is using spigen case, but the case pushed his TPSG out, end up he removed the TPSG...
Get a SP that is compatible with the case u going to use.
Chevalier
Mine hitting 300+
Thanks! Wondering if the wifi chip used in the Huawei lineup is a little poor.
Getting 400-500 on my wife's note 8 and my iPhone xs max.
My Huawei not as strong when testing. Same location, same server.
