Blueberrytea
- Dec 10, 2017
Just gotten the 9.0.0.213 update...
456mb...seems really nothing much
Yup.. just the patch.. i already feedback to huawei team about auto brightness & they still not fix yet..
Sighz
Wondering if the wifi chip used in the Huawei lineup is a little poor.
Getting 400-500mbps on my wife's note 8 and my iPhone xs max. v near the route.
My Huawei not as strong when testing. Same location, same server.
anyone able to hit 400-500 on their Huawei?
I think it's their own hisilicon. 1103.
A lot of people complained they couldn't connect to 5GHz band. I found mine prefers to connect to 2.4G band. To use 5GHz I have to manually connect.
My reference point is my master bedroom bathroom. My m20p p9plus all have v weak connections there. My other phones had no issues there. Even my daughter complained her p10 has weaker WiFi signals.
Having said that I can get 450ish up/down to M1 pt when near my router. Singtel/Starhub high 300 sometimes 400+ a bit.
But the WiFi is definitely worse off compared to my other non HW phones.
For reference s9 under same conditions can get about 500 down 600+ up w M1 pt. Singtel down low 400 but up can go 500+.
My mate 20 has a much better WiFi signal than my Pixel lol. Whenever I bring my phone to the toilet, my pixel will randomly disconnect when I'm watching YouTube but I don't have any issue on my Mate 20, able to play 1080p video.I think it's their own hisilicon. 1103.
Sent from HUAWEI Mate 20 using GAGT
guys any good app to download songs for free? variety of english, chinese, cantonese songs etc...?
i tried downloading songs on my macbook, then transfer to my huawei using android files transfer AND airmore... but once in my phone's google play music, some of the songs get automatically split into different folders/albums etc... very frustrating to not have every songs in the same place..
any idea or alternatives...???
You can fix that yourself if that bugs you. You will have this issue I believe no matter what you use to download the songs because some of them have the song information, and any player will try to sort them according to those information.
Select all songs, right click and choose property. Under details tab, change "album" (just this one) to whatever you want. Then I think the player will sort them into 1 single album with name you have just given.
I am using windows, and not sure what's the equivalent for mac though.
Or simply just use "all songs" from google music player. Nothing is sorted.
Mine is still on 9.0.0.183![]()
I have the same problem when playing POGO only. Mine is mate 20.Anyone faces issue with the colors of the screen? Don't know how to explain but when I play Cookie Jam, the colors of the game seems off when I switch to another app and switch back again. The colors seem lighter and brighter. But after a while, it seems OK again.
Sent from HUAWEI HMA-L29 using GAGT
