Huawei Mate 20
bthw85
Europe started receiving EMUI 9.1 Update.
Singapore is still stuck at 2 month old update (9.0.0.243), with April Security Path.
Mate 20 Pro (Non-Telco Set) using Starthub.
Lols u r not alone.
i am also still on April security patch.
mine telco is M1.
JT2008
Refer to HiCare announcement, 9.1 upgrade starting from 27 June for our region. Need to request via HiCare to receive the upgrade.
1982-1994
Quite similar to Chrome interface, which is what I'm used to so I'm happy! A bit Sian cos my bookmarks and passwords not there :s13: but just a minor inconvenience :s13:
Kiwi browser can backup bookmarks. Have you tried this browser? Got night mode too.
1982-1994
I see m20pro has lte high speed mode setting which is disabled by default. Does it work in Singapore? I tried to enable it but not sure if there is a difference
Sent from HUAWEI LYA-L29 using GAGT
Are you still using the phone?
Yes there's a speed difference. Local major telcos should support it.
Exia14
Can anyone please point me to a good screen protector for M20Pro, shopped on lazada abit but no experience with hydrogel or TPG for this phone and reviews abit vague lol, cant seem to rely on it.
1982-1994
i charge to 100%, before sleep use a bit until 98%, wake up become 94%, is it normal?
Ah gui
How long did your phone left on standby?
If 8hrs, and you're not living underground, that was quite ok.
Like mine drops 1% every hour at work due to underground reception not good.
Drops 1% every 3-4 hrs at home when asleep.
If you're on M1 infrastructure, battery tends to drop faster, maybe due to the lack of fast dormancy.
s-ghost
High Honorary Member
Ah gui
now i never observe liao
that was back when i just got the phone, but battery life have been still good so far, sometimes if i never go out, can last me two days :s13::s13:
sajokj
Got the update today with May patch
Update: 9.0.0.267
Camera also updated. now have AI phone
JayBeeLwashere
Still nothing for me..using singtel and have requested from hicare to np avail
osh6
Maybe you can try HiSuite, update through PC.For some unknown reason, My Mate 20 used to not getting firmware updates through ota and hicare, but when i tried hisuite, i can get latest firmware.
JayBeeLwashere
I finally got it! Waiting for 9.1 now.. Anyone has a link for in depth description of the upcoming features?
leesm123
Hi all, I keep having my lock screen showing 'slide to open' even though I have my fingerprint all set up. I have to reset my fingerprint mgmt N set again. Is anyone experiencing similar? What is wrong?
1982-1994
Ever since I have my fingerprint set,I never seen 'slide to open' anymore.
Because I press my finger onto the scanner and it immediately unlock the phone. Prompt.
Prefer the scanner on the back,works much better than on screen.
leesm123
Prob is I have my fingerprint setup perfectly but after sometime the 'slide to open' will appear. And phone can be easily accessed. Not sure why.
Reboot the phone. And sometimes it will go back with unlock with fingerprint shown on lockacreen. Sometimes it doesn't.
JPadPro
Got the update today with May patch on TPG
Update: 9.0.0.267
