Huawei Mate 20
OutBreak
Maybe is due to Google ban. Now Google support for 90 days nia. After that you on your own.Your phone no resale value.
It got nothing to do with the ban. Normal Mate 20 is already seeking around that price..
tazzi80
Didn't put in my post that I meant the pro version selling at 650.the pro version has dropped alot, which is now less than $50 difference from the non pro version.
GRAVESEED
Any Mate 20 Pro users here could chip in if the green screen issue is still prevalent or has Huawei SG rectified it with newer phone batches? Looking to clarify before making the jump to this phone!
Thanks!
Dolcefarniente
green screen already so called solved. after the first batch is found. most of it being replaced within first 3 month
Thanks!
cottoncloud123
Anyone experience intermittent blinking like from normal screen display, it will suddenly switch to black screen with time and weather forecast at the top right hand corner?
yamkc58
Hi, anyone experience any issue with their Google map? Took a Grab just now and the driver was using a Mate 20 pro. He shared that the map keep bringing him to the wrong way after the last update.
Oinkize
That 1 is grab issue. They are also having issues with waze.
roxas93
Was wondering should o trade in note 9 for mate 20 pro cause battery life of note 9 and camera not that good.
ccmheoa
Guys, anyone know what is the best screen protector now for m20pro?
Prefer without black border
Currently on MBW, but it seems the finger print scanner kinda of works only half the time... Not sure if it's the glass or the phone?
Mi9 finger scanner is so much better
quinnkei
I took a look at the display set at M1 just now the screen burn was so bad....
Most of the Mate 20, Mate 20 Pro display set have burn-in. I notice those in Huawei store had change to a black theme to make it less noticeable.
When you compare to a Samsung S9, Note 9 which are older than Huawei Mate 20 and no issues, will be good if Huawei swap theirs with new units
sajokj
Not updates for last 2 months
I think Huawei stopped giving updates to SG, Other regions already got May security patches and new camera updates.
But in SG we are still stuck with April patch and old camera.
Its time on to move away from Huawei.
No Boot-loader unlock or Firmware update.... :(
