Huawei Mate 20
laeticia
The the search function in the settings. If really don't have, another option is to try out different dark themes.
Reading xda forums now and it's not available on Mate 20 due to the lcd screen. Apparently dark themes has no effect on notifications so it's slightly irritating.
Any idea how to off haptic feedback of vibration and sound? Switched them off already but during setting alarm or set calendar event when scrolling to select time and date, the vibration and sound will appear again.
mds8080
which screen protector are you using?
Im thinking of getting a UAG Monarch case
I'm not sure of the screen protector brand I'm using now. Just went to some small shop at Jem and they pasted it for me. I think the screen protector a bit hard to find and only certain shops will have it.
Soulfly
Hi everyone, Just started using the Mate 20 Pro, it's a great phone. I just updated to EMUI 9.1, at the start, we now have the option to check or uncheck a tick on enhanced services. I unchecked on Hisearch, because I'm not a fan of it but after the phone rebooted. Hisearch is still there. Is there anyway of removing Hisearch? As for Whatsapp, in the notification settings, I switched off vibration, when I set my phone to silent with vibration mode, I don't receive any vibration notification from Whatsapp at all, is it this normal? But when I switch to sound mode on my phone, obviously there is notification sound but there's also vibration. Is there anyway to have only sound but without vibration mode? Sorry I know this sounds silly and in truth, it might be silly but I do hope you guys and girls here can help me. Thanks.
1982-1994
I guess so since I am still at 9.0
Actually ADB removal is easy. can settle within 5mins.
GoodBetterBest
New to Huawei phone. Is the Mate 20 and Mate 20 Pro same ?
I'm thinking of getting Mate 20 Pro but given all these Trump issue, safe to buy ? Thanks very very much.
molecule
Both are great phones. Pro obviously better camera and features. 2y warranty and it will last 2y usage till your next fone if u are not picky abt next Android version and resale value in future.
Challenger and Courts offering a refund program for additional peace of mind if u need it. Smart move by these retailers as it is unlikely to be triggered for existing models.
https://www.msn.com/en-sg/news/sing...our-huawei-phone-loses-google-apps/ar-AADApkR
GoodBetterBest
Both phones, the NFC can be used in Singapore, eg Dash, Ezlink, etc, etc. I'm told for some China brands, their NFCs cannot be used in Singapore.
tk
Mate 20 n Mate 20 Pro are different models. Both are good but different features. Pro got better cameras, curved oled screen n ip68. Non Pro model got bigger lcd non curved screen, fm radio n 3.5mm jack.
Audiology93
Different, but mostly the same. Main differences are camera, display type and fingerprint. Mate 20 Pro has better camera, display and under display fingerprint.
Sent from Samsung SM-G975F using GAGT
Audiology93
Dash, Google pay and Ez link can be used. Tested on my Mate 20.
GReddy G9 RS
Can I used Mate 20 pro charger to charge my Mate 20? Should I get P30 or Mate 20 Pro as my company phone contract is due?
Audiology93
Should be able to, since both using Huawei super charge. Just that the charging speed for Mate 20 will be capped at 20W instead of 40W.
GoodBetterBest
Do you get the Nano Memory card. They seems to be pretty expensive compare to MicroSd and I can't find smaller size (for purpose of storing some data in case the phone need to be reset).
GReddy G9 RS
Ok thanks. Am afraid it will damage my Mate 20's battery due to the 40W.
Sent from HUAWEI MATE 20 using GAGT
