Huawei Mate 20
Audiology93
Do you get the Nano Memory card. They seems to be pretty expensive compare to MicroSd and I can't find smaller size (for purpose of storing some data in case the phone need to be reset).
I Didn't get the nano SD as I'm using dual sim. Yep even the 128GB is more expensive than 256GB Samsung Evo microSD card. Cheapest I saw was 69.90 on Shopee before $10 coupon and 1000 Shopee coins discount.
Ok thanks. Am afraid it will damage my Mate 20's battery due to the 40W.
Sent from HUAWEI MATE 20 using GAGT
Don't worry too much. I even use the 45W xiaomi PD usb c charger and it works fine. As long as it doesn't heat up the phone too much. Heat is usually the main culprit for battery degradation.
Sent from Samsung SM-G975F using GAGT
1982-1994
Thanks to redmi k20 pro and s10+, I don't trust under display FPS.still prefer optical type on mate 20 and mate 20 x ,fast and prompt!
GReddy G9 RS
Thanks n noted.
Beefsteak
Just got the mate 20 pro and quite impressed with it.
Anyone knows where to buy good full tempered glass screen protector for the phone locally and get them to fix for me?
Thanks.
mousepad_88
is there a mate 20 pro with 8gb ram selling in singapore retail shop? I look online and all seems to carry the 6gb ones
ZergRush
For mate 20 pro how to disable in pocket settings?
The ringtone auto adjust to loudest volume when inside pocket
1982-1994
maur_james
Recently after the update, despite setting no vibration for email alerts, I still get vibration alerts.
Anyone else having the same issue?
JayBeeLwashere
Alot of ppl getting this issue includimg myself, seems to be part of why our battery is bad now
Sent from HUAWEI LYA-L29 using GAGT
GoodBetterBest
I'm familiar with the Xiaomi range, eg Mi, Redmi, Pocophone. I wonder what is Huawei range like ? eg dif between P30, Mate, etc.
Thanks very very much.
Audiology93
Mate = Samsung's Note
P = Samsung's S
So P and Mate can be said to be from different series. Mate series usually get the latest SoC while P series is half a generation later, so I'll only go for the Mate.
1982-1994
Despite of many users complain on bad battery life, you guys went ahead from 9.0?
