Huawei Mate 60
winphenom
Have been running between HK/CN/SG for a bit using the P50pro 888 CN version for a while with HK/CN apps, I have an iphone for SG so i cant say for an SG user. No problem here except some apps i cant use like HSBC Payme (HK ver of DBS Paylah), but Gbox has served me well for most of the GMS required apps (dont trust GBox for banking apps) like YUU HK, McD HK or even KMB bus app. CN apps i have absolutely no issues. Warm a little but HOS 3 is very aggressive in killing background apps so things are generally alright.
I use revanced for youtube and the only google app i need to run from gbox is gmaps. I use gmail IMAP to outlook app and my contacts are all on my outlook (including my iphone).
Thanks bro for the reply. Seems a little too much hassle for a less tech savvy person like me. Better stick to easier options.... Hahaha... Cheers
vaxvms
If the performance is between 888 and 8Gen1. Then not really worth it. As the flagship standard is 8Gen2. And 8Gen 3 is around the corner by end 2023.
But good to know Huawei has managed to overcome the odds. Hopefully the next version of P and mate would be the next Sammy killer...
i waiting next P series actually
still using p50pro kirin chip as second phone
stillgottheblues
Maybe oversea users will get different configurations from China. Have to wait for official global launch to know.
jeffrey745
Thanks bro. My exact sentiments but its the choice selection that is a big headache. Looking for another tough workhorse to last many years. May have to go back to Samsung if nothing comparable out there.
How about trying honor magic 5 pro?
jeffrey745
My number one choice but definitely if volte is approved or it might just be a waste of money later. Next will have to look at Samsung or one plus it seems.
I see thanks for sharing. Wonder if honor magic 5 pro comparable to mate 60 pro, in terms of processing speed, camera and batt life?
Purikura
Their FB admin said HONOR is working with the telco to support VOLTE asap.. I hope it comes soon!
winphenom
Everyone is keeping their fingers crossed for honor magic 5 pro volte approval. Honor should check out the response everywhere and get it done fast as it should boost the sales figure.
chooyoshi
Especially when 3g is going to be shut off next year
Purikura
63 中原侯哥发布了一篇小红书笔记,快来看吧! 😆 T33zSiEm5ocreu8 😆 http://xhslink.com/Wr6m8t,复制本条信息,打开【小红书】App查看精彩内容!
Mate 60 Pro is not 5G.
It is 5.5G?
vaxvms
I heard there will be Kirin 9100 in future.
only cna propaganda media wrote this kind of heading : " Where did Huawei get the advanced chips for its new Mate 60 Pro smartphone? The quiet launch has triggered speculation over what’s inside it."
sinkie realli frog stuck in the well
hahaha
