Huawei Mate 9
tcchuin
anyone knows if unlocking bootloader and rooting voids warranty?
The wording on the unlocking page sounds vague to me
TheCaffeEspresso
My mate 9 ok leh.. Maybe you can check which WiFi ssid your phone connected to..(some people had both 2.4ghz and 5th a cfg as same name) ? And also which server you testing with? On both phone server need to be the same for result to be consistent.. Maybe both you choose manually?
Anyway here is my result..
Yes both connected to 5GHz 5G connection.both I manually selected Singtel sever. Tried both same of another sever .Result is same.
Sent from HUAWEI Mate 9 Gold using GAGT
TheCaffeEspresso
Mine ok too, on M1 fibre.
Sent from HUAWEI Mate 9 using GAGT
Maybe I need call up Huawei for a solution
pclow59
Some here says that they were able to download with their Singapore sim card.
The B138 firmware update never appeared with my Singtel sim card, only appeared after changing to my Celcom sim card.
With M1 and also no B138, only 136 which updated only a few days ago.
lovesick009
anyone facing phone heating up during charging ?
mine started to drop % during charging, change both cable. yet to help.
GReddy G9 RS
After updated to B136, my phone battery level drop faster n get heat up too. When on B110, i don't have such issue. But charging no issue, quite fast (same as on B110).
benz1987
Yeah. Updated over last weekend. Only today then I felt a distinct shorter battery life. Then I saw your post here on faster batter drainage.
