Huawei Mate 9
Audiology93
Uninstall all FB related apps(FB, messenger). Use Chrome > Go to FB Page > 3 dot > Add to Home Screen. Currently still monitoring using GSam.
hognairda
Yeah. You guys are right. Need to uninstall messenger as well. Phone left idle will consume about 30% of battery life...Sian.
GReddy G9 RS
Seem that updated to B136 or B138 have battery drain issue. I don't have such problem when on B110. Really regard updating to B136.
walkofwinners
Go to settings, apps, Facebook, battery and disable system wakeup.
If it's an app being the culprit then it's a relief that the phone is fine cause my mate 9 felt really warm when I took it out of my pants pocket the other day.
Deleted the Facebook app and will monitor whether battery drain is still there. Can consider using the swipe app as an alternative.
For me android OS and Facebook were the highest consumption of more than 15% but I didn't even use Facebook app much. Seems like LG V20 users are also reporting a battery drain from the Facebook app.
hognairda
Did all the settings you mentioned above liao. But Facebook is really battery sucker now. Will still drain the battery even when plug in to power source. So delete the app now is the only alternative. Did facebook recently did any update? Lets just hope that they can rectify the issue soon.
formic
try using the apps from playstore "Tinfoil for Facebook" for basic feature only.
Webview version, no permission required.
Disable backgound data, data roaming and close will lock screen.
mingean
Everyone report this as bug in fb
https://m.facebook.com/bugnub/?source=SideMenu
Sent from HUAWEI MHA-L29 using GAGT
pclow59
Any one know how to set the data usage cycle as with your telco billing cycle. Used to be able to do it when using Sony Xperia phone, not able to locate it using Mate 9, only can set monthly by default. Say thanks first if any one has the solution.
benz1987
My facebook uses 6mah of battery on average every hour, though i don't even open it up to use. Is this normal? Whatsapp uses 48mah battery on average every hour, but i do on and off look back to my whatsapp when there are messages. Is this again normal? Many thanks!
MichaelTan
bro your whatsapp is serious!!! 48 is quite high imho....
