Huawei Mate 9
bluecrab
Those who has the Mate9Pro set from Malaysia, is there anyone who uses Auto Android and confirm that it works?
Thanks...
singexpat
using the HP camera.. no edit no PS..
swee bo? :)
for-kel
Anyone else mate 9 get heat up by fast?
Compare to my 3year old Samsung note3 ,my 2 day old mAte 9 get heat up much fast and more warm than note 3 is it normal?
(Playing the same game )
Little_orc
all bros... helpppp
While rooting my mate9, it suddenly went to soft brick. Can someone tell me how to recover this? I try to google, most of them not work for me.
Now my mate9 only able to boot into TWRP recovery.:sad::sad::sad::sad:
musicsg_com
You started off in your first paragraph with something like a "negative" approach.
But then your next paragraph, you speak highly with praise on Mate 9.
So much so it has somehow prompted and induced me to go for it. :)
For a $800+ phone, I think Mate 9 is unbeatable. Most other flagship phones will probably be selling close to $1k. I will get it myself if not for the fact that I prefer ultra wide angle cameras like LG G5 or V20, so much so that I am happy to trade off for poor battery life, which I can make do by frequent charging. Wide angle camera cannot be workaround.
Cyborg
This Mate 9 dual camera features are adequate to my needs.
Hence I am more or less quite close in making the decision to secure one for myself.
kEvinErd
Because metal is a better heat conductor than plastic.
walkofwinners
all bros... helpppp
Did u unlock your bootloader before this?
But once your bootloader is unlocked, there goes your warranty.
Jeremy1
It heat up faster but also dissipate heat faster.
As long as the heat is not trap there, it's ok.
ZhuTou!
700+ :o
Sent from HUAWEI MATE 9 using GAGT
ZhuTou!
all bros... helpppp
Theres a type of small micro usb plug for android phone
Once u plug in, the phone will boot into the menu to access factory reset or flashing firmware
I forget what is the plug call liao
