then the dual whatsapp feature is useless???
I bought bcos of the dual whatsapp....
after trying for 2 day I faint.... is like u need to check whatsapp every hour to see any msg....
now hope software update can fixed this problem.
Settings-Apps, google play services, data usage, swipe down and allow background data. Whatsapp need this perfectly done to make it work fastanyone having issues with whatsapp messages not appearing till the app is open?
Go service ctr check baAnyone encounter random auto shutdown of phone? Encountered twice during 3 mths with this phone. After shutting down, phone cannot on immediately. Can only power up after like 5 mins
was it hot? overheated maybe?
I'm using Mate8 not using dual whatsapp also same problem, messages don't appear till I open the app.I believe u are using the dual whatsapp.
tat what happen to me too.
only option is to uninstall and install again from playstore.
and use only 1 whatsapp.![]()
Improper installation of Google Play Services lah. Just go inside and enable background data for that.I'm using Mate8 not using dual whatsapp also same problem, messages don't appear till I open the app.
Drive to JB or go to 313@Somerset. But not sure if there's stock or only pre order.Hi anyone can help me here? I would like to purchase huawei mate 9 pro but am not sure where i can get 1 set today.
Thanks alot.
no. 313 Somerset does not have Pro, only have the Porsche Design. Singapore not going to carry the Mate 9 Pro.Drive to JB or go to 313@Somerset. But not sure if there's stock or only pre order.
Sent from HUAWEI MHA-L29 using GAGT
Pro got less battery life, lesser performance because of the higher def. And the fingerprint sensor on the wrong side of the phone. I don't even know why anyone desires the Pro when the normal Mate 9 is true to the `mate' philosophy, and a great great phone.no. 313 Somerset does not have Pro, only have the Porsche Design. Singapore not going to carry the Mate 9 Pro.
I also dunoDoes it takes long to check at service center? I afraid that I can't replicate the problem on site and they tell me its normal
Oh yeah my bad. Forgot it's the Porsche Design and not pro.no. 313 Somerset does not have Pro, only have the Porsche Design. Singapore not going to carry the Mate 9 Pro.
Thanks! It's working fine now!Improper installation of Google Play Services lah. Just go inside and enable background data for that.
Don't the Pro have better battery life?
Pro - 87 hours. 12 web, 14 video
http://m.gsmarena.com/huawei_mate_9_pro-review-1567p3.php
Mate 9 - 82 hours. 14 web, 11 video
http://m.gsmarena.com/huawei_mate_9-review-1520p3.php
