Huawei Mate 9
1c3_5n0w
1c3_5n0w
Any one played clash royale on mate 9? When i launched the game, it went into full screen and the navigation keys are hidden. How do you exit from the game?
This is called Immersive Mode, aka Fullscreen mode for phones which have softkeys which was introduced in Marshmallow . It essentially hides the status bar and navigation buttons. To exit it just swipe down from all the way at the top of your screen or swipe up from the bottom of your screen as if to access the quick toggles on iOS with the calculator flashlight wifi airplane mode auto rotate airplay and all that jazz.
Audiology93
Gixxer1000
friedapple
quick question - i bought some mate9 cases off taobao and received quite alot of screen protectors as freebies. there are a few tempered glass protectors but they seem slightly shorter than the protector which came with the phone. if i use those (as they still cover the screen well), there is no halo effect, right? since its smaller than the original protector.
another question - do you guys find it necessary to purchase a screen protector to cover the back of the phone, or the camera lens? there's quite alot of sellers selling this on taobao.
thanks!
mosprockett
Hey when u use the short cut (down volume double press) to start camera, previously it would show like "0.9secs" to I indicated the camera start up time.
However now I don't have it anymore... How to enable again huh?
UPDATE:
OK please ignore.. reset to defaults and the feature came back.
Thx
Sent from HUAWEI MHA-L29 using GAGT
1c3_5n0w
thanks!
I have recently purchased a 3 pack full coverage anti halo (无白边 as they call it) screen protector for $8 shipped. Will update after application. About the camera protector, I don't think there's anything to worry about if your case has sufficient lift for the camera bump.
r0_ger
thanks!
Looking to get s protector for the cam lens too. Link pls.
StealthNinja
thanks!
hi if you are not using any case cover atm then yes i suggest purchasing a screen protector to paste it over but for the lens take note when u paste the camera lens u will affect the sharpness is a certain way depending on how thick the screen protector is..
dribee
Hi all,
I've been an iphone user for past 7 years. Have decided to join android (what took me so long).
Heard good reviews about the Huawei Mate 9.
In your opinion, is there any reason to consider other phone?
I like fast phones with a good camera.
Thanks!
StealthNinja
Hi all,
Thanks!
samsung used to be a good choice but after the explosion, i think mate9 is the 2nd better choice to go for.:s13: VALUE FOR MONEY
xolatw
After updating to B158, my Spotify has problems playing through my car Bluetooth or my Bluetooth speakers at home. Anyone else has this prob too?
Audiology93
Hi all,
Thanks!
Fast phone with excellent camera? S7/S7 Edge, but then again S8 is coming s oon. Mate 9 camera is good, but not as good as S7.
thanks!
Never heard of Mate 9 camera lens cracking unlike the V20 so nothing much to worry about. Putting a piece of glass/plastic over the camera lens will degrade the picture quality especially lower quality ones, but it might or might not be noticeable.
https://photography.tutsplus.com/articles/everything-you-need-to-know-about-lens-quality--photo-14430
dribee
Thanks man. One deal breaker for samsung now is they start removing the 3.5mm earphone jack!!
KeYoKe
i dont trust samsung now even though they announce that they test their batt thoroughly now.
mate 9 got 2 years warranty also
