Huawei Mate 9
ace_mav
Yeah..dislodged and bubbled ever since..bought the full cover sp but sensitive reduce by alot. So gambled and remove..the olephohic quite nice.. Hopefully it last..
Maybe once wear off can put new screen protector..foresee will use this phone very long..really like it alot..
sharang
Qoo10 should have a redemption code for u to go down and redeem. They will unseal in front of u to check the set.
Thanks.. So if order today, means can collect today? Or got waiting period?
Sent from Huawei NEXUS 6P using GAGT
friedapple
just wanted to inform all that i bought the huawei supercharger (china version) for about 25 sgd with shipping and it works just like the one which came with the phone. All i need is to plug in a travel adapter or an adapter that can work with the china 2-pin plug. An alternative for all to consider :)
btw, how do you guys remove the original plastic screen protector which comes with the phone? I tried to remove as I wanted to replace it with a tempered glass protector but its so snug so i gave up and decided that i would only replace when it starts to peel. haha
friedapple
yes the screen protector that comes with the phone is actually quite good.. so i feel sayang and a waste to remove it too.. although all the cases from taobao generally comes with tempered glass protectors as freebies :p
anyway huawei has been aggressively promoting the mate9, saw their ads all over europe when i travelled there recently
OutBreak
Thinking of getting mate 9 or LG v20, dun know which to choose leh.
Just buy Mate 9, you will not go wrong..
Google LG V20 lag, screen retention and boot-loop issue. You will be glad you have not brought that phone. Haha!
The only good thing about V20 are the audio quality and removable battery..
lwandyh
Cos I'm using LG g pro 2 currently. Sometimes if it hangs, I can remove the battery & insert again.. but wat about mate9? Wat if hang, how to remove e battery?
kenstyle
I have tried too many glass protectors and the Hydrogel type. All have issues with either too short at the sides which overlap the screen or cause Halo effect.
Couldn't find a full clear 3D type of glass, and today went to get X-One screen protector.
I must say, it feels like glass but thinner and it leaves only a 0.1mm gap at the side of the screen border.which you wun even notice. Pricing is abit ex at about $40. But overall it's like finally I found a screen protector tt covers the screen well. Rather than trying my luck keep buying from taobao
KeYoKe
You might wan to share where to get lol
