Huawei Mate 9
StealthNinja
Anyone encountered erratic touch screen behaviour? Recently I'm getting strange touch responses, sometimes scrolling will result in a click of whatever is under my finger when I release my finger. Other times pressing the back button once will result in multiple taps detected. Press and hold the back button will result in multiple presses (with haptic feedback), and it's not consistent.
Thinking whether to send in for servicing, or to remove my screen protector and try first.
i dont have this problem maybe u try restarting it, did your device drop in water or did u install any funny things recently? holding back button should not result in multiple presses effect... :eek:
1c3_5n0w
Go to developer options, show touches and see if touch is not detected at some places on the screen. Developer options can be enabled by going to settings, about phone and tapping on build number 7 times. I personally experienced an issue with my LCD touch sensitivity and sent it for warranty already, will be collecting at the service center (at Somerset) and will let everyone know how it went.
standing
White is ceramic i think... Black is brushed aluminium, looks like metal. Gold is polished metal like the iphone jet black, behind is shiny shiny and smooth de, feels like plastic
Ya.. Got to try the gold one.. Was puzzled y it feels like plastic or glass.. Will it scratch or break like glass?
meekiatah
Just bought the original charger plus cable for $48.10 last Saturday from 313 Somerset
sharang
Got the mate 9 last night. A really fine phone. Compared to nexus 6p, it's smaller in size but the screen is larger :)
Anyone using nova launcher? Not sure why when I try to use nova launcher, it crashes and asks me to uninstall the app.
Sent from HUAWEI MHA-L29 using GAGT
KeYoKe
had no problem installing and using nova launcher with mate 9.
did u set the default launcher to be nova launcher?
i revert back using the stock launcher after that though, cos some widgets cant work in nova launcher
sharang
Yup I set the default launcher to nova and encountered this multiple times. Will try research the net and see if it's an issue. Having said that, the stock launcher seems pretty good too, so maybe I'll stick to it.
KeYoKe
its good and snappy. hence i got no complaints about it...
have u tried uninstalling and reinstalling it?
WarCloud7
Has anyone managed to play Flash games either in their Facebook app or via their browser (to login to their FB a/c)?
DaveMusic
I compared its vertical length vs Samsung note 5 with 5.7in screen, if exclude navigation panel as note 5 panel is not on screen, mate 9 screen is smaller when browsing
KeYoKe
if u already bought it then just use it. if havent buy then look for other phones lor
i have switched from note 5 to iphone 7 plus then to mate 9, dont have any issues
