Huawei Mate 9
JPadPro
Got Mate9 yesterday can't seem to find any option for below.
Is there a way to increase the folder window size (3x3) in home screen?
:s11:
Oinkize
I have just joined the mate 9 family. So far so good...
newcell
F/W B158
Encounters twice torch lite ON when taking out from pocket. Not sure anyone here ever happened to their M9.
Torch lite icon not on home screen.
forumer
F/W B158
Happens to me too. When you are at lock screen n you swipe up from the bottom of screen, you will be able to see the torch icon.
newcell
Haha you are absolutely right.
Didn't aware of such useful way to get the torch lite. Not bad to get a quick light in the dark.
So now understand, I must had activated it and during the motion ON the lite.
Thank you.
newcell
Yes it is.
But i have been getting WhatsApp high battery drain notification...
Am getting many app high battery drain notification regularly AND often too.
Till I don't really care anymore.
KeYoKe
Yes it is.
Dont need care. U can turn off the high batt drain notification.
Go to settings > battery > top right hand corner got another setting menu and then turn off power intensive prompt
Oinkize
Icic. The notification seems worrying but good tip to disable it.
Thank you...
