Huawei Mate 9
Promethus
Hi can I ask, for using duel sim,
I using the 2nd sim for mobile data, Bt how can I set it to 4g?
Cos now it at H sign.
I don't think the 2nd SIM can support 4G. You might want to switch the cards around.
I could be wrong, tech dummy here.
KeYoKe
Dual SIM card functions in 4G/3G on this phone. Meaning if SIM Card 1 is 4G, Sim Card 2 cannot be using 4G, so SIM Card 2 will be using 3G.
If you want to set SIM Card 2 to 4G, you have to set Default mobile data to SIM 2 at the Dual SIM Settings. The default SIM for data will be using 4G. But do note that your SIM Card 1 will become 3G after that.
You dont need to switch the SIM card slots
for-kel
Maybe have to change and see how
Your that Sim by default got 4g coverage at the place you are in?
Have usually only using 1sim have 4g cover, cos now.data going limit so change 2sim to use another card data
Yes I did change it to default using sim2 for data,
Still still it go from H and sometime 3g.
Not like last time 1sim only it 4g all the way.
for-kel
There is 2 signal bar on the top right side beside the Batt,
The one on right should be sim 2 & left is sim 1 correct?
Just double checking on this.
Oinkize
Maybe you can try to disable Sim 1 and try?
Oinkize
Try it still on h/3g (mostly h)
Cos now playing game is Vy slow.
Do you want to try to put this sim in slot 1 and try? I have this feeling that is your sim coverage.
Have you used 4g on that sim before?
for-kel
might be coverage... u observe see if it turns to 4g before or not...
Didn't see it on 4g at all, mostly on h
I saw the setting is at lte/wcdma/gsm
It should be correct setting right?
Or will it be possible that my mdata card don't have 4g?
(This is free from m1 when I sign up bb)
Oinkize
Mdata sight have 4g. But if you have not entered 4g coverage before, better call m1 to confirm that 4g vas is added.
ZhuTou!
My suspect or rather own experience, after 1st round of EMUI upgrade, my battery drained very fast. After 2nd round of EMUI upgrade, situation not improved. It used to be able to last something like 16-hour with 50% left, now, below 20%. That means, M9 consumes a lot of energy considering the battery is 4,100mAh. Sian liao.
Usually more updates, more battery needed
U can try like some suggested, go clear factory cache and google service cache
Sent from HUAWEI MATE 9 using GAGT
banana10
So it turns out mate 9 have dual led flash.
One is white. The other is orange.
When I tried to run the phone test, flashlight one was the white led, flashlight two was the orange led.
Any way to trigger the orange led flashlight on?
standing
anyone watch before any drop test vid for this phone?
tried to find mate 9 drop test on youtube.. like no have..
IAmZTX
Don't think anyone that silly to test the durability of this phone. I mean what for? Waste few hundred bucks for drop test? Oh come on..
1c3_5n0w
ahem JerryRigEverything ahem. anyway ya why you want drop test though. you buy such an expensive phone pump in 30-50 on a good case and screen protector la.
