Huawei Mate 9
Oinkize
After calling m1 confirm that the card is not 4g activated.
Now can use 4g liao.
Thanks a the ppl that help
That was what i suspected. I faced the same as well previously.
That's good to know that you have 4g now... Enjoy...
thorsten139
I do game quite a bit on the mate 9.
Mainly Hearthstone, GTA Series and PSP Emu.
I don't touch the mobage stuffs etc.
I find the battery last a lot longer vs my old S6edge.
And it doesn't get really hot. Perhaps it's the rugged armor?
Display wise, yes, Samsung is slightly better, but I don't miss it nor does it detracts me from enjoying the games.
The only time the display gets really hot for me is when I am trying to use the phone outdoor during noon time when the sun is directly overhead. The display will get really hot because the brightness is bummed up all the way and the heat of the sun makes it worst. But, it's the same with any other phones I've used.
Thanks prom bro for the detailed description.
Sounds good. I don't play those crazy intensive games , also running hearthstone while on the mrt etc.
My main concern is heat, my current lg g4 heats up like a crazy **** and then throttles after just playing simple games, and it isn't like i am running demanding ones.
But since none of you guys have concern on heat, i guess there isnt any issue for the simpler games.
looking to recontract this weekend =)
Oinkize
Hope to see you using the phone soon...
Promethus
Hearthstone confirm won't heat up the phone. On an average day, I will unplug around 11am. Usual FB, Whatsapp, Carousell and browsing throughout the whole day. 3pm, Hearthstone, complete missions etc. Typically by 2 to 3am, I should have at least 30+ %. My samsung would have undergone at least 2 to 3 times 50% charge by then.
sunht
Today playing hearthstone, going to win, then battery run out and phone was off. :(
Sent from NEXUS 6P using GAGT
Reeve85
Hi Guys, i am using NFC Transit Sim with Mate 9. Yesterday when i took bus, i encountered the bus conductor. Are they not able to scan the phone using their device? I had to show him my transaction from the EZ Link app.
kiawui
The firmware takes up 11.34gb? Or is it the installation file residing somewhere which I can delete?
Sent from HUAWEI MHA-L29 using GAGT
superio
Hi, is there any place I can get a good tempered glass for mate 9, inclusive of installation service? The current one I'm using have bubbles at the side.. 😕
Oinkize
Go hitech mobile. They sell for $8 with pasting. Mine no bubbles.
chris1987
Dear Bros who use Instagram, do you have issues while filming an Instagram story video using the front camera?
ryan84
Don't have such issue. Maybe you can re install it? Recently I have issue with Instagram when I start using multiple accounts especially the stories.
