Huawei Mate 9
pclow59
I also did not get the alert but when I try the System Update, I got the 181 update
kaysee
Hows the upgrade? Seems like not much feedback about it. Still on the previous version and battery life has been awesome. Thinking should i click the system update.
Globe
any odd chance that you are able to add in the HW leica watermark after a photo is taken ?
update : play cheat abit ...
Globe
Cool photo. Where's that building at?
its the national library at Bugis.color editing using default in cam editor.
Hack sharing : take a black photo with the water mark on. Go to photo editting app to remove black and make BG transparent @ 20mp resolution.
Find image app that can insert picture into picture.
Wala ....
ps use this only when you think the watermark will block your image at the default bottom left corner.
