Huawei Mate 9
kaysee
My experience, latest Software battery a little more draining than 2 versions ago. Phone tends to be slightly heated up while charging. Never experience this before on the 2 versions ago. Not sure if anyone got it same like mine?
molecule
Great that there are many updates within weeks!
Usually I will let the phone settle for some time before judging the battery perf.
meekiatah
Mine on the latest update. About 3 days already. Usage pattern didn't differ much. Battery life remains good. But, now I've been doing auto reboot every night 4 am. Maybe this helps to clear errand apps that might be running.
OutBreak
You're not using Samsung phone, why do you need to reboot every night? :D
tlh107
using the latest update, still hv same problem (since day 1),
sometimes my home screen clock stop(digi clock widget-Forest tree). remove n re pick the icon, unable to add any icon.
then it erase all the icon, I hv to re transfer back the icon back to home screen.
think maybe un-install the clock see still got problem.
Can it be the clock problem ???
banana10
Could be the battery management trying to close unnecessary apps. Have you tried adding that app to the whitelist?
tlh107
Yes this battery program likely cos the problem, but this a build in program can't do much, even it hv the setting for sw on or off, but somehow is not working.
some app can work smoothy, but some u want to off but never off n worst is some u want stay on but it go sw it off.
