Huawei Mate 9
jtch74
New update using Thai Simcard.
Sent from HUAWEI MHA-L29 using GAGT
oh ... new update
alphacool
For 181, I'm getting surprisingly good battery life compared to previously. Barely 10% drop in 3+ hours, compared to 20% typical drop for the same period, same usage pattern.
pclow59
If wifi is turned on then battery consumption gone up, whether is B172 or B181, the same.
Norman Chan
Like to know , For the Mate 9 are both screen shot and photos taking (both front and rear camera) , all format is in JPEG ?
Can the photos taking both front and rear camera format be just set to Raw format ?
RSKeisuke
Do you guys use your mate 9 with BT earphones for music? Would like to check if your handset seems to perform with that slight bit of delay while the music is being streamed over BT? Delay can be felt most when launching app from home screen. Other tasks seems fine.
Sent from 华为 MATE 九 using GAGT
kewellz
Have this problem too, feels like youtube audio always not in sync visually when i use my Bluetooth headphones.
meekiatah
Not sure why, but my battery consumption today is extremely high. As at now, I had already been through 3rd charge from 10% ++ to 100%.
deckcard
Usually caused by backup services went rogue. Reboot if you have unusual high battery consumption especially after charging.
meekiatah
Thanks. Did a reboot and now is back to good battery life. Morning 7am till now balance 60%>
