I'm still using B183 version. Haven update to latest B188.. thinking of wait for the the next update to be more stable first
I play Pokémon Go on my Mate 9. No issueshi guys, i know this sounds passe, but anyone here playing pokemon go with your mate 9 or p10+?
i'm thinking of getting these phones.. i'm not really chaser of technology so i don't mind an out-going model if it's cheaper. but knowing that android can be more laggy than iphone, just wanna ask for real world experience for those playing pokemon.
TIA
I contacted Huawei tech support, this is their answer.
This may be a power consumption issue. If the system detects that an app is consuming an excessive amount of power, it will forcefully close the app to extend the device's battery life.
To prevent the system from closing excessively power-intensive apps, go to Settings > Battery, touch the settings icon in the upper right corner of the screen, then disable Close excessively power-intensive apps.
I tried it, and it works. I told Huawei that, this is not the intended use, because the function only supposed to close background apps, but not foreground. They told me that the next firmware release (they are pushing) will remedy the situation.
I play pokemon with mate 9'so far okhi guys, i know this sounds passe, but anyone here playing pokemon go with your mate 9 or p10+?
TIA
Thanks. Useful info. Shall try... Been closing some apps randomly lately after I updated. My wife using Sony Z5P. Experiencing similar issue.I contacted Huawei tech support, this is their answer.
How to get in touch with the technical support? Or are they here in the forum? The software like got bug, sometimes saved contact number will disappear, then later reappear again. Plus the mobile data usage monitoring doesn't have the option for us to input a auto reset date based on billing cycle.
TIA
It's a v good priceThank for advise. Qoo10 selling @ $538 now. Good buy ? Thank you.
Seems like there is a firmware B189 been released. I received mine.
Yup i also receive it but i keep michaeltan setting betterSeems like there is a firmware B189 been released. I received mine.
