GReddy G9 RS
- Feb 12, 2008
So is it recommend to update to B188 firmware?
Up to individual. I always update to the latest.
Okay can you try to disable your mobile data, WiFi, Bluetooth then enable your location information? See if google map will point you to your location. Only thing that wouldn't work is if you need travel direction from one point to another. Cause usually only with mobile data or WiFi then it will work, in this case, it works even without such connections. But it only tells you where you are on the map, even as you walk.location services depend on network, wifi receive, bluetooth and gps. If cellular data not available, wifi and BT will still receive, gps will still work.
Okay thanks. It's actually more ideal to have it as a default function in the phone to reset based on billing cycle. Otherwise it kinda defeats the purpose, and then to only download another application to monitor usage. I guess it could be due to multiple accounts that's causing the contact syncing issue, then again, shouldn't the the phone be smart enough to handle this hahaha. Cause I didn't come across such issues with my previous phone, it also allowed me to set a reset date for mobile data along with call time and sms.for billing cycle please use telco app.
For contacts sync issue, it's google code. if you have multiple accounts syncing you are sure to have all kinds of issues. For contacts I only have 1 account syncing with no issues.
To get technical support, just key into your Hicare app in the phone and they will respond fast.
If this is a new feature, I think it's good to have. Just worried if there will be any data charges while overseas. Funny thing is that even when roaming data is disabled, it still works haha.Okay can you try to disable your mobile data, WiFi, Bluetooth then enable your location information? See if google map will point you to your location. Only thing that wouldn't work is if you need travel direction from one point to another. Cause usually only with mobile data or WiFi then it will work, in this case, it works even without such connections. But it only tells you where you are on the map, even as you walk.
It seems that the location services will still work when roaming data and WiFi is both unavailable. For example when in google maps it will still be able to identify the user current location as well as when the user moves. Is this normal? Or is it a connected Telco feature? Don't know if will be charged data usage not.
Thanks. I just find it interesting that the blue dot still moves without connections, and without google map offline.I can still use Google Map offline: my location is a blue dot and it still recommends the most direct route to my destination. This means that it is still usable without WIFI and data. You can test via the following steps:
1. Download Google Map first so that it can be used offline.
2. Turn off your WIFI and data access.
3. Re-start Google Map and search for directions to your destination.
I also read about long press but it doesn't work. Can anybody try? Cannot find anything in camera settings.According to this article, it just requires long pressing of the shoot button.
https://recombu.com/mobile/article/huawei-mate-9-camera-review
My Mate 9 should arrive today. Kind of late to the party but the discounted price is good.
Sent from HUAWEI MHA-L29 using GAGT
Found.How come after i do a factory reset the phone manager disappeared.
use the phone until 1st year going to up then crack the screen for the one time replacement LOL. no it doesnt warrant against that.Anyone, know the screen for mate9 got warranty against scratch? Don't know y I got a few scratch on the top of my phone, 1st time got scratch one the phone.
Sent from ZTE A2017G using GAGT
after warranty period must really take care of the screen though. if dont want buy protector just leave the preinstalled one there at leastLol that what I think also.
My screen warranty til March next year. Hee
Ya it seem that the screen get scratch Vy easy.
So sad..
i m using x-one screen protector, pricey but i think easily worth it. 70rm at csq.There are some full-screen protectors for Mate 9 that cover the top and bottom bezels completely, so you won't be able to see the top and bottom scratches.
I ordered mine from a Carousell seller who is pricing them at $1.50 only. I have yet to receive it though.
My Mate 9 arrived yesterday and its camera is really quite fun to play with. The screen is good, speed is fast and charging is quite rapid.
Sent from OnePlus ONEPLUS A3000 using GAGT
