RSKeisuke
- Aug 26, 2000
screenshot the changelog here pls
Ownself quote ownself...
I just received B189.
Singtel post paid.
Read the changelog, nothing except sept security patch
Singtel post paid.
U updated ardy? Is there still have app force close?
Will Mate 9 get the update till Android P?
Considering but worry that model will be 'outdated' as I plan it as a long-term purchase
When i was on 188, i encountered only about 3 or 4 times in total. Not too sure if 189 will fix it, but reading the changelog, this is just updating the android security patch to September.
Why don't you try disabling "close excessively power intensive app" in battery settings?
Ok.. so if I remain my old version can right?
everytime theres a security upgrade i strongly recommend upgrading. this security patch, to put it in extremely layman terms, patches a bluetooth vulnerability.Ok.. so if I remain my old version can right?
for billing cycle please use telco app.How to get in touch with the technical support? Or are they here in the forum? The software like got bug, sometimes saved contact number will disappear, then later reappear again. Plus the mobile data usage monitoring doesn't have the option for us to input a auto reset date based on billing cycle.
it's all in the hiCare app.Does anyone know how we can get the prices of accessories? Tried searching on huawei webby but din see any.
location services depend on network, wifi receive, bluetooth and gps. If cellular data not available, wifi and BT will still receive, gps will still work.It seems that the location services will still work when roaming data and WiFi is both unavailable. For example when in google maps it will still be able to identify the user current location as well as when the user moves. Is this normal? Or is it a connected Telco feature? Don't know if will be charged data usage not.
indications are Mate 9 will sure update to Android O (from public news and postings).Will Mate 9 get the update till Android P?
Sent from ZTE A2017G using GAGT
Go to software update.How do I update the security patch? mine still verisonB138... I haven done any updates yet?
