thumbtacked
- Mar 20, 2015
have a problem, why are my messages from carousell not pushing through? is there something i need to set?
notifications are on.
Waiting for the Oreo update.
Hi, does Mate 9 has the depth of field feature as on P9 Plus? As in after taking a pic, I can change the depth of field of image. TIA.
Thanks. This feature is not available in Mate 10.
Yescan check with users here, huawei's supercharge cable's connections are purple on the inside?
Using Mate 9, anyone experiencing wifi got disconnected and can't login?
Seems difficult to connect via wifi.
Using another phone: Note 4 to try, no problem in connecting to home wifi though.
but these rly are a good 'long term' phone tho bc they stay fast compared to the s7e. it got to the pt where i had to reset it once about every ~3 months for it to stay smooth on nougat which was why i sold them.
Sent from LENOVO LENOVO P2A42 using GAGT
Me use for 1 year without any reset. So far I am still enjoying it everydayisit hype or the phone really stays fast after 1 yr?
