Huawei Mate 9
townman
Another with trouble logging into wechat after applying 360(C636)?
The progress bar will move and stop at about 90% and the app does nothing after that. Even when I try to click on "help" or "faq", the same happens with the progress bar stopping at about 90%.
I don't have issue login on Wechat after applying 360 but had problem on open subscription account page, at the end, just do factory reset and everything back to normal, you can scroll back on my post
fatboy
Thanks the directions worked for me. However for the last part, after pausing, i had to go back to my wifi setting and set back to auto for proxy before i could download
eyz
great!
enjoy!
Gondon72
after update to the latest versioin (363C(636)) yesterday night, my mobile data seems like not working. able to make phone call but not able to surf..reset, reboot, shutdown also can't resolve it. Anyone has any idea?
*resolved, APN setting was cleared off. I got to retype it and it works
fatboy
I also updated last night. I only saw 360a as the latest. Everything seems to be working fine. Data / apps all intact
alphacool
Battery life on Oreo seems better than on Nougat. But need to override the battery management settings on some apps like email clients, otherwise notifications won't come in.
mbgeow
guys, check with you all, where can buy mate 9 good temper glass screen protector?
thhours
Did the update yesterday, the lock screen images are longer perfect fit for me, they're slightly zoomed in and it looks awful. :(
GReddy G9 RS
Yes, better battery life but need longer to fully charge as compare to previous.
alphacool
Just realized that Oreo battery management is so aggressive, my calendar widget doesn't refresh and freezes after some time. Apparently the guys in XDA developers are discussing the same issue happening to Mate 9 and Mate 10s running on Oreo.
Stock calendar widget supposedly works without this problem.
GReddy G9 RS
I don't have any issue cos i set all to manual instead of auto.
Sent from HUAWEI MHA-L29 using GAGT
RSKeisuke
An update to my issue... Seems like it's due to my acct being deactivated due to inactivity, but the strange thing is I was able to reactivate it in Japan but not in SG.
So this may not be due to 360 firmware afterall.
mafia86
After upgrading to Android 8, my notification bar shows all icons when I swipe down.
Does everyone who upgraded to Android also faces the same thing?
I still prefer the collapsed notification bar only showing the top row when swipe down in Android 7
