Huawei Mate 9
wilcam
I find it weird too. Don't know is my gps got problem.
Sent from HUAWEI MHA-L29 using GAGT
My Mate 9 also starting have the GPS error prob when playing Pokémon Go after I updated to the latest Android 8
mbgeow
Weird... Used to have the same problem but doing that solved it for me..
Now my error is go plus disconnect every time catch a pokemon using go plus :s22:
Sent from the Moon using GAGT
change.to.new.pogo.plus battery, can be no.battery
Algaenite
That's what I thought might be the cause too.. But this time like never use as long as the previous batt.
Change batt le then see how first :s22:
eyz
clear the cache?
off the phone. press and hold volume up and powwr button together till the huawei screen.
then wipe the cache partition.
Algaenite
Hmm, the go plus doesn't dc if I only spin stops with it. But if catch pokemon with go plus, every catch dc :s22:
Algaenite
Anyone encounter this timing bug too?
lwandyh
Anyone use auto Bluetooth app? Meaning when there is incoming call or outgoing call, Bluetooth will auto on itself. Cos before oreo, version 7 can support those app. Oreo version not friendly
wherehouse
I din get any update to Oreo till a Msian Digi Sim was used.
Now there's 8.0.0.362 (C636) installed.
Still no volte on Singapore operator, but Malaysian Operator Sim has volte.
roxas93
Mine having the step tracker problem won't count steps. Only when I open up the app then can count else background won't do the counting.
tlh107
battery drain fast
main use is wat app n dolphin, the battery like get drain faster n faster.
last time graph like go down at 45deg. now is at 60deg.
one day use can still hv >50%, now is 40-30%.
top of the list is dolphin n screen with >30%.
when sleep mode is ok, go is horizontal level,no sure is same,i think a bit worst than b4.
