Huawei Mate 9
mbgeow
like need to backup data n such or leave the.phone at service center for a few days.for the battery change..?
BombVoyage
if going service center, better to backup all your data, do a factory reset, remove sim card sd card before handing over to the staff
meekiatah
Cannot i tried. They will check any problems with the battery if no problem they won't change it for u under warranty
Any idea how much to replace battery? Phone still under warranty but guess battery warranty already out. Dec 2016 phone. 10 mins drain 10%. But, phone normal use is still good.
Sent from Xiaomi MI MAX 3 using GAGT
lwandyh
This phone is superb! But will it have the gpu turbo update for this? Or there wont be anymore updates ardy?
magixz
I tempted to buy poco f1. Will it be a downgrade?
Sent from HUAWEI Mate 9 using GAGT
Nevereatrice
I never ask them how much that time. Also like to know. Mate 9 is still very good and snappy after updating to android 8
If change with a fresh battery will be perfect. Currently battery can last me a day or two and i have used it for more than a year. Really power
