Huawei Mate 9
caterham7
what is the point of having the black n white cam ah?
got ppl take black n white photo everyday one meh?:s22:
wah.. nice photos..
but black n white can just use filter right? how come need a special lens ah?:s11:
can shoot color first then convert to monochrome?
if i may provide some info... using p9 as an example [since am using it]
personally am another one [besides jimmy tong above] who shoots b/w regularly
https://www.instagram.com/evozero/
b/w is especially useful for street photography, when you want to remove distractions and view a photo's composition, or a person's expression in a photo
the mate 9 [and p9] uses 2 sensors, one colour, one monochrome [not special lens]
can we shoot in colour then convert to b/w? yes, definitely, but the result is different. For example, google online for p9 vs honor 8 comparisons; you will see that the honor 8 uses a filter instead of shooting directly with the monochrome sensor, and the resulting photos look different
using a monochrome sensor also means "removing the traditional colour filters in a typical RGB image sensor, the light will hit the image sensor at full spectrum, unfiltered, allowing the image sensor to collect full information with minimal losses."
source: https://robinwong.blogspot.sg/2016/08/a-full-monochrome-image-sensor.html
Robin Wong's blog post explains it better than me and with many comparison photos; do take a look
jimtong
good explanation!
Sent from LGE LG-H815 using GAGT
tikokia
Sharing some of my monochrome shots
zoomed in
gavthang
just got my Mate9 today... coming from BB Priv.
This is a solid phone for it's price.
I got it at Starhub reseller @ Nex for only $39 via 4g 4 plan and CIS.
Comes with Smart cover and color band as well... super good deal.
Was $239 last week without gifts...
caterham7
Hey... Have u all experienced WhatsApp msg delayed prob. Everytime I must click the app only those messages appear. I tried to reinstall.. still getting this prob. Help?!
delayed whatsapp notification seems to be a ongoing issue for china brand phones; this was what i changed on the p9 previously; hope this is useful for mate9 users
  1. Advanced settings->Battery manager->Protected apps, can set which apps remain in memory (and which gets closed)
  2. in recent apps, drag down whatsapp, u should see a "padlock" appear
  3. in advanced settings->battery manager->protected apps, turn on for whatsapp
  4. in settings->apps->whatsapp->notifications, enable priority display
  5. Settings --> Apps --> Advanced (At the bottom of the screen) --> Ignore Optimisations --> Check that Whatsapp is Allowed
  6. Settings > Apps > Whatsapp > Battery > Turn on System Wakeup, App auto-launch and Keep running after screen off
but frankly, huawei should try to solve this once & for all; like a setting to deactivate all battery saving at one go
benny888
wow! i've not really checked but the last i noticed (when i slept at 100%), woke up to be 80%. my wifi is turned on.
Mine with wifi on, 3g/Bluetooth/GPS/sync off drain overnight over 7-8 hours is about 4%.
You must had lots of wakelocks in background with such a high drain
standing
Thanks for explaining.. I saw one part in the blog that says that the b/w lens also provide more clarity for the color mode..
As I'm usually only takes color photos.. Anyone tried b4 taking a color photo while covering the b/w lens.. N see if got any difference?
Anything_Whatever
Seriously.... is that a deal breaker for you?
Why not hang around for another 2 months for the release of OppO r9s... it supposedly has a better cam
http://forums.hardwarezone.com.sg/a...ppo-r9s-r9s-plus-5446149-4.html#post104800249
standing
caterham7
yes it does make a difference; for safety, camera software will warn you that the b/w sensor is blocked
