Huawei Mate 9
vincent829
Mate 9 Dual Sim
Hi, can anyone check if Mate 9 can first SIM on 4G and second SIM on 3G? Or second SIM will limit to 2G only?
xtemujin
Normal charging, the world charging will be displayed.
Super charging will be displayed when you are using the supplied charger.
Just got my Mate 9 yesterday from Sitex.
Current Note 4 dying so did not have patience or time to source for a cheaper alternative, ie Lazada, qoo10.
Paid $898 for the set and comes with the following:-
1) Flip case
2) VR Goggle
3) Color Band - to be redeemed from Sim Lim Square Level 4
4) Extra Huawei USB C cable
Just a few questions as i am new to Huawei.
How do you know if your phone is fast charging ? Is there any notification or function that will state that it is fast charging ?
As there is no dedicated Numeric row for google keyboard, any recommendation for a alternate keyboard that works like the Note 4 keyboard ?
Folders created in homescreen are relatively small when expanded (3x3). Is there any way for me to increase the size ?
Where can i get casing and tempered glass protector in Singapore ?
Many thanks!
ThErMuS
a lot of shops i asked do not carry the accessories yet. im using mine without the full cover too and im very scared i will scratch or drop it :eek:
yea yea.. i also worried.. can share where you bought your casing?? i am thinking of going down to sim lim later to go see see look look... i just need to get one "cover all" for the time being first.
game goondu
can i check with u guys....
at the mem and storage...
did u set default location as internal storage or SD card?
if i choose SD card, it give a warning, "Your phone has been encrypted. Please make sure your new storage location is secure before switching locations"
what does the above means?
do it means it will encrypted the sd card or what?
basically i only want to store my cam picture and video in the sd card, i do not want to be encrypted as if the phone is spoilt, i can still insert my card into a reader and retrieve all my photos and videos....
king
I visited a few HP shop, look like not too much accessories available for Mate 9 yet.
hyourinmaru
Anyone manage to do entire backup with mate 9 yet? Although it keeps opening my HiSuite but it does not not detect mate 9 to connect it... Sigh
walkofwinners
Looks more like ur phone has been encrypted and not ur sd card.
Anything_Whatever
It's normal.... when you lock your phone with fingerprint and passcode... they will show encrypted.
You can try... turn off the passcode and fingerprint access .... see whether you get this message or not.
Anything_Whatever
@ hyourinmaru'
When you connect to PC, usually there is a message whether you are connecting as MTP or Camera mode.
There is change you selected the wrong one?
game goondu
i got passcode.. so the mem card will not be encrypted...
tested out. remove passcode, still give this message when i select sd card.
what setting did u guys set? phone mem or sd card?
foosoomin
Hi Mate 9 users,
I have a question to ask
For those using older model of wifi router, do you face compatiblity issue ?
Is your phone able to connect with the older router, yet cannot surf internet ?
If yes, please write a complain letter to Huawei consumer support email, tell them the problem
skaade
i went last fri. nothing yet. doubt it will arrive anytime soon. i ordered some from taobao over the weekend. currently using the provided case which exposes the top, bottom and sides.
micshang
Hi, how do guys wake up the phone? I tried the knuckle knock thing :o but doesn't work. Is it only by pressing the power button? Any advice? :)
