Huawei Mate 9
lockks
Telco requires you to sign mobile plan.
For tourists and foreign visitors, you can try:
MobileSquare, or Whymobile at Far East Plaza, Scotts Road.
Hitec-mobile at Bugis, North Bridge Road
Handphone Inspiration at Marina Square.
Google the shop names for the addresses and contact numbers.
Forgot to mention .... you can also try to look for it at the airport transit shops... could be cheaper there.
PS - I won't recommend establishments like Courts, Harvey Norman, Challenger, Best Denki as they usually sells at full recommended retail price.
you miss out red white mobile at the cathay and kasia mobile at suntec. but if you dont want warranty go visit little india Naranjan Electronics. tons of handphone shops for you to compare prices. somw prices are cheaper there but may not sell the latest phone.
caesium2108
I also have problem connecting to my bluetooth headset w my mate 9 😥 it worked on all of my other phones. Siannnn
Anything_Whatever
I have no experience with RWM and Kasia, so I cannot recommend to our Friend here.;)
cnstar
Apparently not, but I use another app to track data usage so I'm not too bothered.
ok thanks, just wanted to confirm it's not hidden anywhere. can't believe they don't have such a basic function. what's the use of monitoring your data limit if you can't set it according to your billing cycle :/
shager
You're right I didn't notice it. But why not using the M1/SingTel/StarHub app to do it? I'm using these apps and it is very accurate, and always reflects the billing cycle, as it's linked to you account.
Anything_Whatever
what's your car model bro? not sure what can we do?
I tot he meant headset.... as in headphone and not car..
Ya... at least he should be more specific to put the brand and model of the Bluetooth device for awareness so that others can check out and advise.
Hello_M0t0
Sorry guys, may i ask how to transfer all the stuff from my old samsung note 4 to huawei mate 9? Noob here.
Anything_Whatever
https://www.bluetooth.com/~/media/files/specification/bluetooth-low-energy-security.ashx?la=en
Mate 9 uses BT 4.2 with support for BLE
Maybe you guys read up the BT compatibility chart and see whether you can find the answer from there.
Or alternatively you can post your questions through the Bluetooth Report Q&A
http://bluetoothreport.com/bluetooth-versions-comparison-whats-the-difference-between-the-versions.
forumer
You may download Phone Clone app from play store. Its easy to use for transfer of everything from your old phone to Mate 9.
duckling
Any Apps or ways to transfer settings like Wifi passwords?
The Note 7 is no longer with me but I've backup the Samsung SmartSwitch file in my SD card.
