Huawei Mate 9
princewenle
Whats wrong with yellowish?
Its healthy for our eyes isnt it?
Btw heard some bro complain on the fingerprint sensitive. Use the smart cover flip from huawei can solve the problem.
You can pick up or reject the calls with the cover.
You can close or dimm the display without wait or press power button.
Sent from HUAWEI MHA-L29 using GAGT
Rubick
If whole screen yellowish i am ok. But just part of the screen. Uneven color that is y
miltonwkw
It's totally acceptable when the screen is warmer if it's evenly spread throughout. For the OCDs issue, it's just the bottom somewhere right above the back button which tend to be more yellowish than the rest of the screen.
Sent from HUAWEI MATE 9 using GAGT
mafia86
I am still thinking whether to change to tempered glass or not. The default protector seems good and ok
ZerozeroZero
i feel like can see a lot of oil stains. last time use redmi note 2 with tempered glass dont have, now have. cant be i suddenly damn oily right. :o:o:o
symbiote28
anyone used the powerbank given with the phone? need to confirm if it really has 'super charging' combined with the usb given with the phone or actually it's the same as all other powerbanks and that the only supercharge is via the wall adapter? thanks.
oDes
guys, I have confirmed mate 9 is not compatible with starhub VoLTE (at lleast for me)
Maybe other users from other telcos can confirm this too.
Zon
Seems like the original cable having extra pins is true.
It's prob using a dual charger system. Meaning the cable have extra 2 pins acting as a 2nd charger. Thus the original adapter supports double the amps of other phone chargers allowing it to draw more.
Check out one of the testing where non original charger and cable is only 1.2amp compared to using original cable and it draws at max 2.1amps.
http://forum.xda-developers.com/mate-9/help/quick-charge-3-t3509594/page2
For car owners like me.. we can try finding a car charger with a port that supports highest amp. Then use original cable for faster charging.
Previously the 5amp car charger someone posted prob wun work as it's likely 5amp across 3 ports.
Another idea that I have... since current adapters what we are using is max 2.1amp. If we have the circuit diagram of original cable and better understanding of its charging system. We can customise a cable where it's 2 ports into a USB type c.
So where every we go. We plug into 2 ports into any multi chargers and can draw more amps avail for the phone. Humm. food for thought.
Zon
Prob a better idea will be customise a 2port male into a USB female. Then use original cable.
Then it will have the total amp available to draw. If the 2 ports are 2.1amp each... Then total will be 4.2amp
Anyone wants to try? Lol.
