Huawei Mate 9
kenstyle
I am using an Aukey 2.0 Qualcomm fast charger in my car. Sadly the car charger charges up only normally on the Mate9. The charger charges fast on my other SD phones
did you use the Huawei cable?
My own assumption is tt u need a higher output to drive close to 5A for the original cable to deliver fast charge. However now there is no car charger with 5A output.
ckling
any recommendation for the tempered glass? the one apply by default is normal screen protector only right?
mafia86
Anyone uses NFC SIM for Mate 9? Good to have?
I forgot can use and only changed my SIM card to normal nano SIM because old SIM card is micro SIM which I will be billed. If I go change to NFC SIM kanna bill again very xiong leh
sam39sg
:s13:
micshang
I'm using the NFC Sim. It's working very well for me. Just tap the phone :s12: Remember to turn on your NFC function if you wanna use.
princewenle
Last night I charged my phone until 93% and set it to ultra saving mode and unplug the charger before go to sleep.
This early morning I want to set it back to normal but looks.like the phone is lagging badly and the touch screen doesnt responding.. ended up restart the phone and press hard continuously.
After restart then its okay again.
Anyone ever encounter this one?
How to prevent it?
Sent from HUAWEI MHA-L29 using GAGT
lovesick009
1.phone auto reboot
2. font auto changing
3. i stopped fingerprint sensor as it's too sensitive. unlocked without realizing at times.
4. stuck with side button and top icons after rotate
other than all these. it works well,
benny888
No...just a generic cable from my Nexus6p days
miltonwkw
Rubick
Thanks. Good to know. I guess they are all using the same LCD panel and it's just how prominent the yellow tint is and rma won't really solve it until they have new supply of panel. But once u see the tint , it becomes obvious and tend to look at the spot every time. Damn OCD acting up. *********
Sent from HUAWEI MATE 9 using GAGT
Yup. But might be due to lighting also. Perhaps you can go into settings and under display there change the color temp to cold. Helps a little
ckling
i recall last time iphone also got this issue, the solution is it will go away after some period of time?
miltonwkw
Probably not. I had the same yellow tint issue with LCD panel since Oppo Find 7 and 7a and OnePlus one and now Mate 9. All of them are LCD panels. I guess it's the way LCD panel are made to light up the screen that is causing it. Either u notice it or u won't . It's really not obvious and affecting the phone performance in anyway. Still the mate 9 is a great performer in daily basis.(from my 4 days experience with the phone) I'll still recommend the phone to anyone out there sitting on the fence whether to get a new phone.
oDes
anyone on starhub getting 4G/voLte on their mate 9 during a voice call?
Mine always switch back to 3G during a voice call.
Rubick
Probably not. I had the same yellow tint issue with LCD panel since Oppo Find 7 and 7a and OnePlus one and now Mate 9. All of them are LCD panels. I guess it's the way LCD panel are made to light up the screen that is causing it. Either u notice it or u won't . It's really not obvious and affecting the phone performance in anyway. Still the mate 9 is a great performer in daily basis. I'll still recommend the phone to anyone out there sitting on the fence whether to get a new phone.
Alot of ppl wont notice the yellow tint too and many wont even bother about it. Unless OCD ha
