Huawei Mate 9
miltonwkw
This was the reply from Huawei in regards to the intermittent / delayed notification:
Thank you for contacting Huawei.
We sincerely apologise for the inconvenience caused to you.
With regards to your inquiry, given that the issue has persisted after the troubleshooting steps provided to you, we would need to escalate this information to our relevant department and we will get back to you as soon as we receive a response from them.
Your patience is highly appreciated.
Should you have further enquiries, please do not hesitate to contact us at 800 852 6666. Our lines are open Mondays to Sundays from 9.00AM to 9.00PM and for further support, please visithttp://consumer.huawei.com/sg/support/index.htm
Thank you and Best Regards,
Jay
Huawei Support Team
Sent from HUAWEI MATE 9 using GAGT
RSKeisuke
To check whether the phone is compatible with your current telco VoLTE, go to a spot where 4G is strong. Call someone, if the 4G icon is still there it means your phone can use VoLTE on your calling network. If 4G changed to 3G or H+ on a voice call, it means your phone is not compatible
I'm on singtel. No VoLTE in sg.
The Kirin 960 supports VoLTE according to the technical specs. I guess it's down to singtel here.
Sent from HUAWEI MHA-L29 using GAGT
RSKeisuke
non tempered glass right? i heard the tempered glass also very small just to avoid this problem, like that still worth to buy tempered glass or not?
i think stick with normal plastic SP is better, unless a perfect fit curved TGSP is available, but that requires a highly skill applicator
Audiology93
Product Model: Mate 9 Dual SIM(MHA-L29)
Warranty: Your device warranty is till 2017-11-28 in Singapore.
only 1 year nia... so its 1 year or 2 years?
I have checked with the staff over at Huawei Store at 313. Confirmed 2 years. Different country has different warranty policy so it will only show 1 year when checked using the website. But be rest assured that it has 2 years warranty after confirming with the staff.
Sent from OnePlus ONEPLUS A3000 using GAGT
