Huawei Mate 9
audioenslave
Regretted immediately after replacing the original screen protector with flat TGSP. The curve edges of the screen causes poor adherence at the edges of the SP
Sent from HUAWEI MHA-L29 using GAGT
my tempered glass good and cheap from q0010..adhere to screen no problem and is 3d type..this tempered glass at the Huawei logo has a hole type to enable the logo to be seen.
Audiology93
Thinking of getting the mate 9. Just like to check with users here the dual sim is 2g? Saw this discussion at the P9 thread, hence just like confirm the details on Mate 9. Many thanks.
4G+3G :)
stajin
anyone know where to buy huawei mate 9 PRO (non-porsche design version) can buy online or in HK?
limcc
My mate 9 only 77mbps download. Any settings need to set. It could my mate 9 problemđŸ˜‚
Mine is worst at ~60Mbps, tested with Asus RT-68 and RT-88, 2.4GHz or 5GHz. Just to be sure, I tested the HTC 10 and it did ~400Mbps down. :s22:
RSKeisuke
try turning off mobile data and speedtest again, strangely i did that i get faster throughput.. compared to my N6P, mate 9 is slower...
anyway i try not to be too bothered abt it. normal surfing or streaming videos won't make a diff
anyone knows if the wifi+ feature in mate 9 actually work? or just gimmicky
