- Jul 5, 2001
i dont have this leh but unlikely since its too niche for those apps to even consider supporting
cannot use google pay. Huawei pay only.If you install GBOX:
1) Can use Google Pay for NFC payments normally?
2) Will location history be available on Google Maps? (My other phone on China ROM - Location history does not work)
Oh bummer.. Looks like have to buy the backward and costly Galaxy Fold 5 den.cannot use google pay. Huawei pay only.
No location history.
Basically is work around so not everything can work.
Try using Singtel dash lor. U got try lighthouse ? Can log in Google map and see history but the guided navigation not so good as they cannot pinpoint your location realtime ( due to no gms)Oh bummer.. Looks like have to buy the backward and costly Galaxy Fold 5 den.
Yes it is working. You shoudl actuallly install lighthouse first and then Gdrive and install whatsapp. Then when inside whatsapp, backup automatically with Gdrive . Usually whatsapp contacts will take some time to populateHi guys, can I check if you are using this phone and WhatsApp, are you able to display the names of your contacts instead of just the phone numbers?
I have tried lighthouse, Gbox, etc to download WhatsApp and google drive, but I can't get it to display the names. I have also tired the online methods to remove/sync WhatsApp account, etc, but nothing works.
Appreciate any inputs and TIA.
Hi Guys, is there is Huawei telegram chat group around that huawei users can join to share tips or experiences? Pls share if there is. thanksYes it is working. You shoudl actuallly install lighthouse first and then Gdrive and install whatsapp. Then when inside whatsapp, backup automatically with Gdrive . Usually whatsapp contacts will take some time to populate
Actually I use diff method. I just download the lighthouse APK from xda so I never change region at all but the method u mentioned should work ( did that for my previous m50p)Thanks for your reply. I'll try it out later.
Another question; did you change the region back to Singapore after installing lighthouse? I changed back cos some apps are different in Malaysia region.
I still couldn't get WhatsApp to display the names. This was what I did:Actually I use diff method. I just download the lighthouse APK from xda so I never change region at all but the method u mentioned should work ( did that for my previous m50p)
Did you backup your whatsapp contacts onto Gdrive using your prev phone ? After that is confirmed, then try to install whatsapp and backup from Grdrive. I suggest to use the whatsapp from Apkpure, sometimes the whatsapp from petasearch or app gallery would be the one optimized for huawei (without GMS). In this case since you are using lighthouse to simulate GMS, you can use the google enabled one.I still couldn't get WhatsApp to display the names. This was what I did:
1) downloaded lighthouse via xda, logged into my Google account.
2) downloaded Google drive via apk, so far so good.
3) downloaded WhatsApp via petal search.
I then logged in to WhatsApp and restored chat, and only numbers were displayed.
So, I did a backup to Google drive and it went through. However, as of this morning, the names were still not showing.
Think I'm missing something cos when I click the new chat icon (bottom right green icon), there's nothing in my contacts list (even after clicking refresh). When I click to check the contacts option (3 dots on top right), it shows nothing as well.
It's like all my contacts are stored in Huawei account only and nothing in Google account. I downloaded Google contacts app previously and it showed nothing as well
Not sure what else I need to download or steps to follow.
I tried the steps that you suggested, but still couldn't.Did you backup your whatsapp contacts onto Gdrive using your prev phone ? After that is confirmed, then try to install whatsapp and backup from Grdrive. I suggest to use the whatsapp from Apkpure, sometimes the whatsapp from petasearch or app gallery would be the one optimized for huawei (without GMS). In this case since you are using lighthouse to simulate GMS, you can use the google enabled one.
try and let me know if it works.
Indeed, unless your workplace forced you to use GMS locked in apps.Most people don't really need to use GMS actually unless you are using Google for work.
