Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
kashix
S10+ fingerprint I feel not as responsive but probably more secured due to its technology. The responsiveness will reduce substantially if you use a tempered glass.
So far I applied tempered glass on my P30 Pro and the responsiveness feels similar naked. I'll have to monitor longer for now.
Hi bro, asked u earlier but didn’t get a reply, can share where you got your TG and how much is it? Thanks a lot
athenodorus
oh didn't notice. i got mine at red white. $30. But i have to warn that it's not case friendly and i only know this particular case has no issue.
vaxvms
Hello. . . Ask u all. . If I buy online carosell. . This seller don't provide with receipt. Anyway to safeguard my warranty? Sorry to ask this noob question
Sent from OPPO CPH1611 using GAGT
reg huawei online and u can check warranty validity
gabrielworld
Guys I just bought the Huawei p30 Pro for my wife and realize the charger that came with it, doesn't have fast charging unlike the Google pixel 3 I had..
Do I need to get the higher Volt in order to have fast charging?
eriol125
Its 40W fast charger leh. Mine no problem. I think u need go service center change liao. Lemon charger
Sent from HUAWEI VOG-L29 using GAGT
samsungXP
i feel that my p30 screen a bit yellowish compare with my honor 10.It is the screen protector problem ?
Sent from Honor 10 Phantom Blue using GAGT
invigo79
Did you enable the eye comfort? It will make everything yellow because it disable the blue light.
Sent from HUAWEI ELE-L29 using GAGT
samsungXP
or bcoz oled and lcd look different.i never on eye comfort.display is vivid mode.So now i choose cold mode
samsungXP
reviews say that Oled display is a bit yellow compare with lcd
