Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
kyleongwl
Hi! How much was your tempered glass protector at red white mobile?
Saw online there's this zealot branded tempered glass @ 49. Touts that it uses a uv activated glue to keep the thing in place.
The one (TG) from challenger. Full adhesive tape....not affecting fingerpeint reading. Smal bubbles...(getting less after 1 day)
Silverback84
30 bucks......
Silverback84
Apparently the screen protector at red white mobile fits the original transparent case that comes with the phone
Silverback84
Look for the lady at red white mobile, she is experienced with the application of screen protector for p30 pro.
athenodorus
They told me the same but I went home n tried then found out it is possible
It may fit initially but you'll never know if it will push up the glass after awhile.
So best is you test for a few days before spreading the info. Anyway all these accessories related stuff should post in a separate thread.
Beh-Hawk
hi, is it only the 256g is available in sg? i read that they have the 512g too?
cokiee
Just got my tempered glass sorted out. Using some uv activated glue as well, but not of the zealot brand. Dude doing it also told me it won't fit the original casing, and even after he was done he reminded me once more not to try as it'll force the tempered glass up.
I asked if Uag will work and he suggested not to also cause its usually quite tight. Hmm wonder what will work as a casing now.
Silverback84
Where did u do yours?
Silverback84
Have to go back to red and white tomorrow again. My spigen wallet flip case unknowingly cracked and I don't even know how in the world it happened and I did not dropped it.
