Huawei P40 Series
Dasarpagi
On fw189 for P40 non pro. When I try using googlefier on the first step (install the "backup"), it says installation failed
Does this mean my phone not compatible with googlefier? Or just this particular fw?
Sn0L@rx
U mean adding credit card to phone and using it as pay wave? Yes, there are few banks' credit card working using the phone NFC payment.
Which bank can work with the NFC ? So far I know is only know is icbc bank..
Sent from B@ L0ng L0ng using GAGT
Zapiron
Came here to clarify some doubts...
1. Downgrade to .131 cause .114 is very buggy
2. It is possible to upgrade to the latest version if you want to using the same hisuite method just put in the other link in firmware finder and the version name with GMS inside the phone
3. I recommend not to upgrade as it make the system abit "slower" --> laggier in my case
Zapiron
Downgrade your version to .131
WTS008
Good news. New tracetogether in app gallery otp works now.
dingdung
This is certainly a good news to all Mate30 & P40 series users. I was putting up my p40 pro in Carousell to sell due to some of the apps especially TraceTogether still unable to work well even after sideload GMS. Thankfully i saw this news. Shall now remove my ads in Carousell and keep this phone😁
WinMe
managed to install tracetogether on my huawei y6p HMS version but.... QR code not working. 3rd party QR code working though.
only_lonely
Any new method to sideload Google?
Mine suddenly Google keep prompt enter password. But I think I reset it somewhere so now keep prompting.
Wanted to redo gms again.
lorettatay
How u all survive wo gms? Sas that grab can't be used as it uses google map. My mate xs still waiting for gms as I uses grab aolot
Sent from Samsung SM-F916B using GAGT
pinky867
Can anyone enlighten me?
I cannot login to POSB and DBS banking app, always get "technical difficulties, please try again" message.
I downloaded both apps from apps gallery.
Stock OS, no sideload GMS.
Anyone having the same problem?
lorettatay
Mine OK leh
Sent from HUAWEI Mate XS using GAGT
saltyprince
Hi,
Can someone point me to where i can find reliable fw131 to download, tried to google but some fw for middleeast, some for europe, not sure if its the same.
Thanks
tohchr
No issue with POSB and PayLah! App. Can login using fingerprint also. No GMS or whatever, using straight out of the box.
saltyprince
Downgrade to firmware 131 using hisuite & hisuite proxy
Googlefier and managed to get GMS
Happy
BTW, I dl trace together from Huawei and it works perfectly
botak siak
Happy
To which 131 fw did u downgrade???
Them did u upgrade the fw???
What is the latest update for singapore p40pro???
