Same here. No problem with using 5W charger
Question!
Can we charge the Ipad mini using the 12W charger that comes with Ipad 4?
Will it spoil the ipad mini?
Similar problem encountered. Currently I am on 200mb Singtel Firbre Optic. Today just received my Ipad mini (16gb wifi+cellular) and once I started using it, I noticed the loading speed when connecting to appstore was so much slower. Tried downloading afew apps, the download speed and installation was pathetic. Tested the download speed with speedtest, managed to get 20-30 mbps without fail. With the network speed I'm getting, didn't expect the download and installation to be so slow, can feel the lagness. I am pretty sure it is either the device/hardware issue.
Initially I thought it could be my network problem, but I tried downloading apps with my Ipad 2 and there is not issue with it. Even tried using the speedtest on both Ipad 2 and Galaxy Note 2, download speed can easily reach 30-40 mbps.
Let me make a guess, you are using Google DNS. If I'm right, then go use the OpenDNS or your own ISP DNS.
I'm not sure about it. How do I go about identifying if I am using Google DNS or ?
Check that your WIFI DNS settings in your iOS device is not either 8.8.8.8 or 8.8.4.4
If you are using DHCP, check that your router/DHCP server is not assigning either of these 2 IP address as DNS server to your iOS device.
If you can't be sure, try manually set the DNS server(s) temporary to either 208.67.222.222 and/or 208.67.220.220 and see if the problem is resolved. I can't be sure if SingTel is indirectly resolving thru Google DNS or suffering from the same issue as Google DNS
My iOS device is currently using DHCP, but the WIFI DNS setting is not 8.8.8.8 or 8.8.4.4 but 1xx.1xx.x.xxx
I've check my router DHCP server and the IP address is the same as what it is indicated on my WIFI DNS setting.
Unix:
dig ax.init.itunes.apple.com
Wndows:
C:\> nslookup
Default Server: XXXXXXXXX
Address: X.X.X.X
> ...... DNS ANSWER .....
No. Won't spoil. In fact will charge faster.Question!
my mini can only charge up to 93% max using the supplied chargerwill try to drain out the batt and re-charge..
Try reboot it after you unplug from the charger, it should shows 100%.
Hi, I think I owe some answer to some forum friends here. I did not call the tech support anymore. I gave a real last shot. I bring the two 5W charger that cannot charge fully, to my office to charge. For the last 5 days, no matter what battery percentage my iPad mini is, it can simply charge to 100%!! My conclusion can be three factors. The temperature in my office is rather cold. So the charger will not be that hot. Secondly is that I keep charging it with my iPad 12W charger before I decided to give a try in my office. Thirdly maybe the default power point in my room got issue. Now the last thing I could try is to switch to other power outlet in my house to charge, using the original charger.
The very first time I charged it... show 89%.. I reboot showed 93%...I draining it out now... gonna do a full re-charge...
same here. mine was showing 90% and after reboot shows 94%.
should we call Apple Support about this issue?
Have you guys gone thru the battery full cycle charging for a few times? Try to do that and it should revert to normal.
I went thru full battery calibration mode for 4 times, by draining the battery until ipad mini cannot even boot up, and charge all the way...still kana stuck at 90%. I call Apple and they keep insist it is software issue and want me to hard reset and also refresh OS. I fed up bring to my office to charge instead. No problem so far charging in office. Maybe really be the temperature issue. But why for those who have this issue always stuck at 89% - 90% one? Cannot be so jun temerature reach max at these two points mah...
