iPad Pro 2021
Parka
Hi guys, is there any difference from buying ipad at apple store or from mobile phone shop sellers? Mobile phone shop seller seems cheaper. Or is it better to get at apple shop?
It's the same thing, get it cheaper at the mobile shop. I rarely buy direct from Apple unless no other choice because prices from Apple are fixed until the next model comes out.
cheng34
-anyone seen a lower price for Logitech coMbo touch at $244 ?
Which Pro model?
For 11", Qoo10 Logitech Certified Store, $239 after $50 coupon. Think u can apply shop coupon to get further discount
For 12.9" maybe u'll need to look elsewhere
Kunkka
can the case and screen protector for 2020/2018 pro work for 2021?
Snoweagle
Screen protector yes, but case for 2018/2020 may not work well on the 2021 model, depending on your type of case, because the speaker grilles are shorter on the M1 model and a litlle off position from the 2018/2020 models. The cases will fit but on some cases where it covers the top and bottom, some speaker holes may be blocked.
lionelfoo
pros..... soo i am thinking of getting the 11 inch 256 5g version..... any idea where should i get from cos i missed the educational offer..... should i get it now? or wait till shopping mall promo e.g. capitaland extra stars earn?
Glariel
can try shopee or lazada. they have offers every now and then
Janet90
Does anyone here play games on iPad? any idea if the switch pro controller will work... I understand that the PS controller does works ...
TIA
Snoweagle
TIA
My iPad Pro is my main gaming device. I've the Switch Pro Controller but not tested with iPad Pro, it's only meant for my Switch in docked mode.
RocketBunny
Flash deal+ stack coupon or discounted price + coupons can get at quite a discount sometimes on shopee/Lazada
Janet90
ooo I was contemplating to get the pro controller... don't think I'll be using it on my switch thou... hence the hesitation.
Snoweagle
Not worth using a controller just for your iPad, at least to me.
Snoweagle
that’s true… unless my playing style on my switch changes… Thanks
iPad can just play as it is as some games needed the accelerometer and gyroscope functions. Having a controller is a plus but it's not made for iPads. 😁
faded11
Just discovered a permanent black spot on my 12.9" ipad pro screen.
Does warranty covers this?
