Snoweagle
- Sep 6, 2005
Just discovered a permanent black spot on my 12.9" ipad pro screen.
Does warranty covers this?
Bring it back to Apple.
anyone notice that the ipad pro 11 3rd generation, battery depletion seems to be very high ?
i used to have a ipad pro 11 1st generation but later pass to a sibiling and then bought this 3rd generation but find that the battery life is quite poor, 1 day watch youtube and play games until end of day left less than 10 % while at home
how to justify if the battery is not good ?
Hey guys, if normal ipad usage for work & browsing, 11 inch is enough right? what are the main reasons people choose 12.9 over 11? TIA
Apple SG and MY sharing same stock, there's no issue with it.Besides shopee, Lazada and eCapitalmall, are there other places to get IPP at lower cost? I read that the IPP fm shopee is from Malaysia, any issue with the IPP set fm Malaysia?
You should be able to get a SIM card that allows you to share data o notes same plan, but you will need to pay a recurring fee. The problem is that the monthly plan is not cheap either, I.e. 10+, for essentially just the service of allowing you to use another SIM card. If that is the case, you may be better off getting a SIM only plan for a slight top up and with its own data. Depends on you.Newbie question here .
i currently own an iPhone and plan to get an iPad Pro .
Is there any way to get another SIM card for the iPad and share the same phone/data line ?
No issues. I've bought from Lazada and Amazon SG's Apple Official store quite a number of times. All the goods are from Malaysia, but I can register them locally.Besides shopee, Lazada and eCapitalmall, are there other places to get IPP at lower cost? I read that the IPP fm shopee is from Malaysia, any issue with the IPP set fm Malaysia?
There are conflicting information online about whether Apple products come with international warranty or not. I suspect the answer is no, but to be sure, I suggest you reach out to Apple customer care to get their response.I may be going to US in April.
If I buy Ipad Pro in US, will the warranty be applicable in Singapore?
I think the magnet may be too strong. I ran into this issue before, but if my memory did not fail me, it was on an Android based tablet or phone. In the end, I ditched the cover.Hi guys,
Just got an iPad pro 11 and paired it with a Spigen Rugged Armor Pro. I noticed that when I flipped the case to the back, under certain circumstances, the iPad ends up locking/ unlocking on its own. It's as if the magnet is detecting on the opposite side.
Anyone experienced such an issue before?
