iPad Pro M4 2024
longdi
Thanks bro. Maybe that is my missing bits. I use direct USB-C to DisplayPort cable. Maybe a USB docking station with power passthrough will works better. Will check it out!
auzzuro
Usually I use iPad to watch video I got a iPad Pro with M1 chip so this 2024 version iPad Pro watching video does it make a difference intern of colour brightness compare to my old iPad Pro
Hardware4455
nano-texture display glass - is this available for demo at Apple Stores?
waiting for very long finally a matt kind of looking iPad arrived
stanlawj
Below's my review from artist perspective.
Warning! Video is 50+ min
Or text review for those who want to save time
https://www.parkablogs.com/content/artist-review-m4-ipad-pro-2024-apple-pencil-pro
The brightness lifespan of the OLED M4 Ipad Pro will be decreased significantly with your outdoor sketching use (max brightness, warm outdoor temp). That's a big con for OLEDs, as it is well-documented that OLED degrades with brightness and temp, compared to inorganic IPS.
Parka
But unfortunately not something I can test until years later
limpe84
Isn’t this what that tandem OLED screen is designed to address?
Conan1986
Wondering how are you guys are handling this eSIM situation.
I used to swap my spare phone SIM to iPad when I need to and since this is not possible now, the only way forward is to either sign up for a new eSIM data plan or forego cellular altogether and rely on hotspot..
I’m thinking of taking up mobileshare plus to utilise the 5G and data of primary plan but not sure if it’s eSIM compatible..
Deceased
For me I just save myself the hassle and get a cheap data plan ($10+) solely for my iPad.
stanlawj
wind30
I went full wifi after using cellular for years. Not a good experience. Connection to iPhone hotspot outside is slow so most of the time I have to manually connect. Reaching home, it stays connected to my iPhone hotspot and ignores my home wifi…. Has to manually reconnect
Anyone has different experience? Not sure if I am doing something wrong.
