iPad Pro M4 2024
runforyourlife
Moderator
Moderator
Scan the QR code again. Technically it's still binded to the same IMEI so it should still connect. But not sure if telco will charge you for so called transfering or reactivating.
If we sell the device lei? Must deactivate the esim? lol
runforyourlife
Moderator
Moderator
Delete esim from device and rescan on new device lor. That would be chargeable though
I had a hard time activating it..
End up took a few tries.
Cos of the errors, i realised once its scanned once, it cannot be used again liao. It’s odd. I’m from Singtel.
wind30
I bought a spigen, standard glossy tgsp. Looks great on the standard glass pad pro
wont the screen protector affect stuff like glare and reflection? i am always very impressed by iPad anti reflection and I just use the apple Smart Folio + AppleCare. Had a few accidents, need to claim warranty but I find that is the lightest combo with best screen quality.
wind30
It’s available on pre-order already.
I bought the apple keyboard, nice to type and all! Typing this now!
But quite heavy ~~
The new keyboard looks so much better than the old one. I am tempted to buy even though I almost never use the keyboard with my tablet because of the weight.
Deceased
Yea I bought it and it is better to type with compared to the older ones. But logically, I don’t type much with my iPad and the weight is heavy enough for me to not want to carry it everywhere.
I have the thought of just returning it and use a folio instead.
runestyx
Similar to phone screen protectors, if you use those. Applecare, can't help with scratches, SP can easily change another.
runforyourlife
Moderator
Moderator
But after u got used to the keyboard, you won’t wanna give it up. It’s like a laptop if u get the settings right!
Deceased
No leh, my old magic keyboard is like being used as a “stand” and “case” most of the time. I thought I would use the keyboard more often but in reality I just find myself using the touch screen instead.
I feel like if I want to type something like emails and documents, I tend to just do it on a laptop/pc instead. My use case is mainly media consumption and gaming so it feels silly to not return the new MKB and save/spend the money elsewhere
maxheadroom
… I am facing eSIM activation problem as well. Am from Singtel. They just manage to convert to eSIM for me Just now. Been trying to reset the network setting but still not able to activate the mobile network…
It stated “your mobile stat plan did not successfully activate…”
How did you manage to get it work?
Rubick
After convert to esim will need a few hours before activation
