iPhone 11/11 Pro
keechiu
Last the whole day for me. Morning 6am took out from charger and only charge when I’m about to sleep at 10~11pm.
Screen time around 6 hours per day. WhatsApp, social media apps, Spotify and web surfing only though.
how long does iphone 11 pro max battery last?
metamofia89
Wow seems like MG really short supply even at Apple Orchard, check every morning still OOS except on Tuesday only a limited amount restock. Seem like this is a sign for me to get Silver instead :s13:
Yeah both the SG and MG are always oos for the Pro model. Guess we now know what colours are the hot sells.
Jirachi
MG... if you use non-transparent casing also cannot tell. End up is you know only. Put transparent casing also hard to tell, people will think it's space grey. My friend bought the MG, i also thought its SG. End up i malu.. he also 1/2 sian.
Your friend confirm feel that way. MG is supposed to be a flexing colour.
IceX
Anyone knows how to see if the crack on your screen is the crack of the screen or the screen protector ? Just dropped my 11 pro earlier :/
cet87
use johnson and johnson baby oil and rub a bit on the screen.
If the crack "disappear", it is on the screen protector.
metamofia89
Try running your fingernail on your screen protector and see? Taking out the protector would be the best way to tell.
I mean you are considering to change the protector after the crack right? So might as well take it out now and check.
alan_shearer
Yup, whichever one that is cracked you still need to remove the protector in any case.
waterballoon
Jewel got Green color, yay!!
