iPhone 11/11 Pro
metamofia89
Will the oleophobic coating on iPhone 11 Pro wear off?
Not using any SP now :o
It will wear off after some time. Make sure not to wipe your screen with alcohols like isopropanol or put your screen to a direct source of fire.
KeYoKe
Silver the sides get scratches easily but advantage is can polish, but i dont want to take risk for the polish to enter the gaps between buttons
The silver looks a bit like gold due to some angles
But overall space grey and silver is the color i will go to for ip11 pro series and with crystal clear case it looks awesome. But personally i went for space grey
KeYoKe
I guess you’re asking if you’re signing from telco which one can rip the most margin profit right?
iPhone 11 Pro Max Midnight Green 256GB. Handphone shops taking in at $2000 now as of this posting. Must understand price fluctuate any moment.
That is if you can get the stock from telco. Don’t activate your phone (don’t need to put SIM card in). Telco ppl will ask u to open and check the phone for cosmetic issues. You can choose not to put in SIM card into the phone.
WhyMobile, Mobile Square and Red White Mobile all taking in at $2000.
U r wrong. If u dont put sim card, they will still plug in lightning cable into the phone to activate the phone (at least if getting from singtel that is what they did). Safest bet is recon online and get it delivered to your house/popstation to gurantee a sealed set
Jirachi
No. No need SIM cars now to activate. They will connect to the internet at their shop and activate for you. You have to activate it anyway. Apple’s policy.
argentinafa
Oh ok. I got my first set from m1 they just let me check cosmetic but didn’t plug in lightning cable/insert sim. Phone not activated. I sold off this set due to cosmetic issue.
argentinafa
Why would anyone expose a $1000 phone to a fire? 🤣
YouTube JerryRigEverything lor. I srsly dunno what’s with the using of lighter fire to burn the screen test is for what purpose. I cringed each time he does that, and also him using the penknife to scrape the metal band, the sound it produced arghhh!
metamofia89
I clean with water and towel only can? :o
Better not. Maybe the hardness of our tap water can also damage the coating :s13:
Just use a decent microfibre cloth lor. That's what I do anyway. If the coating is there then the smudges and crap will come off easily with a single wipe down.
derrickgoh
Just moved from the super sunny outdoors to indoors.
I can understand if the phone’s screen changed to brightest setting so i can read under the sun.
But it also changed to darkest setting when i went indoors. That I don’t get. Its rather dim so if it auto changed to darkest setting, how to read?
I hope its just the AI being temporarily silly & not some hardware issue.
metamofia89
If I am not wrong, he's testing how long the pixel can be turned on when exposed to direct source of extreme heat and if the pixels can 'recover' after turning off once the heat source is removed.
The test is too extreme IMO but that's how he does it haha :s13:
Jirachi
You should be happy that he did that in his video and nothing happened to the screen.
Jirachi
keechiu
Anyone using M1 line and your iPhone keeps on auto connect to shopping mall’s wireless@sg?
Tried to forget the network but iPhone still auto connects to it... :s22:
