iPhone 11/11 Pro
gerrickchua
Just moved from the super sunny outdoors to indoors.
I can understand if the phone’s screen changed to brightest setting so i can read under the sun.
But it also changed to darkest setting when i went indoors. That I don’t get. Its rather dim so if it auto changed to darkest setting, how to read?
I hope its just the AI being temporarily silly & not some hardware issue.
I think this is where machine learning happens? as the user thinks that the adjusted brightness when moved indoors is too dark and manually changes the brightness, your phone will learn and adapt in the future.
derrickgoh
If I am not wrong, he's testing how long the pixel can be turned on when exposed to direct source of extreme heat and if the pixels can 'recover' after turning off once the heat source is removed.
The test is too extreme IMO but that's how he does it haha :s13:
Reminds me of the jack @ss who flung his iphone 5 out the 2nd storey window then complained apple lied about the screen being tough cos the screen cracked 🙄
Zakhri32
Silver the sides get scratches easily but advantage is can polish, but i dont want to take risk for the polish to enter the gaps between buttons
The silver looks a bit like gold due to some angles
But overall space grey and silver is the color i will go to for ip11 pro series and with crystal clear case it looks awesome. But personally i went for space grey
Yeah I know that’s why I straight away put a naked skin on the stainless steel but I know it’ll get scratches eventually. I’m a total OCD guy but trying to train my brain not to care so much haha, also people say let the scratches be and treat it as ‘patina’
Skintobones
This morning first time I felt the stuttering. More like hang. From lockscreen, I swiped up and the phone stopped partway. I can see half the clock. Then screen totally unresponsive for several seconds. I press power button and only after 2-3 seconds then screen black out. I press power button again and then screen normalize back.
This is on my pro max.
Sent from OnePlus GM1910 using GAGT
What version of software are you on? Do you have a lot of folders on your home screen?
Sent from Xiaomi POCOPHONE F1 using GAGT
foxriver
Someone offered 1020 for my 256gb xs max, 97% battery health in perfect condition no scratches. Worth it?
manofsorrows
I remember got 1 year a phone (forgot which model) fell into the mrt tracks. It had a tech 21 case on.
