iPhone 11/11 Pro
ash like snow
Thank you all! Is there anything I need to take note of (in terms of checking for defects) for ip11? Saw some threads on dead pixel... My last contract was 2011 so... Kinda lost touch :o
Sent from Xiaomi REDMI NOTE 4 using GAGT
ash like snow
And how to transfer whatsapp chatlogs from android to ios? Is backuptrans the only program to do so?
cnt
I think check for scratches and things like that
RocketBunny
Dust underneath camera lens.. important.. :)
benz1987
Touch screen sensitivity
Hi,
I seem to be facing some issues with the sensitivity of my touch screen where sometimes, lighting up does not seem instantaneous upon touching it. Mayb I wasn’t tapping hard enough or maybe it is due to a tempered glass screen protector which is currently applied on it. Anyone face this issue before? What would be a recommended solution? Many thanks in advance! Phone was bought through a recontract with StarHub.
cnt
Hi,
Remove the screen protector
Glariel
Check for dead pixels, dust underneath the camera lens, speakers, test everything until you song then go
ash like snow
cnt
Thanks! :)
I would prefer a clear casing, which brand/any recommendations if soft tpu too cheapo?
You order already? Now singtel price quite attractive. Btw I using esr clear case from AliExpress
balzebub
Glariel
Which is better? 11 or 11 Pro?
My contract can be upgraded in February so don’t know want to choose what phone
ash like snow
Yeah I'm considering singtel, will go down tml! But I asked their CSO and they said the additional 5gb for plan is only applies to "purchase online". Means diedie need buy online liao?
cnt
Buy online lah. I using StarHub and all my phones are bought online. Anyway when checkout see whether can choose collect at shop. Otherwise they send to your house still ok
ash like snow
For the same amount of price for plan, singtel has 10gb and m1 is 17gb though. But I heard many m1 users saying the net coverage quite bad
cnt
Then get singtel lor. Now they having $150 off handset right? Not sure about your usage but I never use up to 10gb with free weekends data
ash like snow
$150 handset and another $30 if purchase online. But end up the price still same as m1 tho
