iPhone 11/11 Pro
Franky37
Can anyone recommend if it's worth it to get telco phone support (Mobile Swop/ Fone Care/ SmartSupport) if I am getting AppleCare? Or should I ditch AppleCare for telco phone instead?
cnt
Maybe you compare coverage and price
PetPet
Moderator
Moderator
I would highly recommend AppleCare+ over third party warranty extension services.
MinMin85
I had this problem previously.
It was because I changed my app store's region, and did it incorrectly. It caused a problem with my Apple ID, which resulted in me not receiving any prompts for app updates.
You should try checking your Apple ID - location, payment methods etc and the problem should be fixed.
Thanks, hope it helps
Franky37
Not sure if this is the right place to ask... please let me know if I post in the wrong thread.
Have gotten my iPhone on Friday and WA migration has been an issue.
I've tried using backsuptrans but it keep poping out notification that I need to install the downgraded WA even though the tutorial mentioned that the software will install for me.
l0cAvsS
Any expert care to share how to resolve this?
P.S. I can't seem to upload image.... Here's the link instead https://imgur.com/a/l0cAvsS
ash like snow
planning to recontract for ip11, but im thinking of 64gb bcos its the lowest price :( does 64gb able to store many apps/pics? i dont play games on hp, mainly IG/FB/ some food apps only
cnt
What phone you using now? 64gb quite ok if not too many apps and photos
cnt
I currently used up 90gb but a lot of junk inside. Never delete any photo since iPhone 4. 64gb with iCloud I think I can survive
cnt
xiaomi redmi note 4 :s13:
i have over thousands of pics now :s22:
total apps maybe 20
Should be ok. If you use iCloud photo backup, you can store original in cloud and smaller file on phone. Easy to access original from phone also
ash like snow
from what i see online, singtel offers free +5gb for ip11.
free weekend local bundle means weekends data is FOC? not under the given GB of the plan?
cnt
Ya, look like 10gb + free weekend. Maybe you can compare with Starhub plan also
ash like snow
Not sure for Singtel but Starhub you can also check when they delivered
if just for basis usage like IG/FB/taking pics, ip11 shld be sufficient? the battery difference between pro/max is like improved abit only i think?
cnt
11 is good enough. Max battery is much better. 11 and pro quite close in real life usage and should be enough for normal usage
