iPhone 11/11 Pro
KeYoKe
IrisKoh88
What I observed about my iPhone was that it is still charging when I wake up for work. Normally i won’t take the phone off the charger till I’m about to leave house for work, so probably the phone already knows my pattern and the time that I will take it off the charger hence it will only start charging the remaining 10-20% battery at the final 1-2hrs.
iPhone got so smart wor???
calvinlim18
Anyone experienced instagram app not showing any notifications? Only when I open the app then I’ll know there’s notifications. Tried reinstalling still the same
dest86
Hi guys, need some feedback from you all. I am using HK set 11pro max, does Apple centre have a spare HK set to exchange for me if my phone can’t be repaired,?
KeYoKe
Hi guys, need some feedback from you all. I am using HK set 11pro max, does Apple centre have a spare HK set to exchange for me if my phone can*********t be repaired,?
No spare set. Usually they will repair unless certain circumstainces then they will 1 to 1. And since they do not have HK set they will need to order for it, before replacing with u
dest86
Thanks for your quick answer, at least I am assured I won’t make a trip down to HK for exchange.
KeYoKe
Thanks for your quick answer, at least I am assured I won*********t make a trip down to HK for exchange.
If repair also same thing, if is a spare part only used for HK set they will order the parts and repair for u. So in both cases the turnover time will be longer
royfrosty
Sorry guys i got a surprise today. I got a call coming in from my phone. Despite it is on Silent mode. I didnt wanna pick it up. But for some reason my ipad was actually ringing for it instead. Got freaked out lol. How do i remove it. Lol
GeForce
On your iPhone,
Settings > Phone > Calls on Other Devices
dest86
I just hope can be repair on the spot. Because my Face ID not working. Currently at bkk went to Apple service centre , they say need go HK to 1 to 1 exchange
KeYoKe
Go the the orchard apple store and get it service. Some of the bros here service their hong kong set there before. apple international warranty so should be fine
PongRareRare
For iPhone as well? I thought iPhone excluded from international warranty.
Anyway, any simple way to transfer and watch mkv videos? Currently using some file manager but it lowers resolution though file size is the same
PongRareRare
Using nPlayer, seems good. Anyone with same problem can try
